Old 06-27-2002, 11:42 AM
svx_commuter's Avatar
Cam Seal
I am going to change my CAM seals and I wanted to know if a puller was required for the sprocket?
Old 06-27-2002, 12:51 PM
SHISVX SHISVX is offline
hey, speaking of cam seals...just got 2 of mine done and a new timing belt for only 442.18!!!
good luck John
Kelli
Previous owner of the
Princess Pearlie "Dimples"
as of 8/6/03
1992 LS-L Pearl 124k
"Yeah, that thingy!"
owner of the new 1992 LS-L Pearl "Susie"
I am a pessimistic optimistic. I think the worst is going to happen, that way when it does, i don't feel as bad, but if the best happens, i am twice as happy.
Old 06-27-2002, 12:56 PM
CGLathrop
Im Interested
I was thinking of doing this also. If you can, take pictures and let us know how hard or easy it is. Step by step instructions would be nice too..
Old 06-27-2002, 03:46 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Your biggest problem will be holding the sprocket while cracking the bolt loose. After that it's a piece of cake - no puller needed.
I don't know what your plan is for removing the seal, but I usually use a 1/8" drill bit and carefully drill a hole in the old seal. Do not scratch the camshaft with the drill bit. Then insert a hook or 90° pick into the hole, using a pair of side-cutters or pliers to grip it while prying against the cam snout. Be sure to lube the new seal before installing.
Old 06-27-2002, 05:04 PM
Can I use the same big strap wrench I use for the crank pulley?
Any concerns about the drill chips getting inside the engine?
Silicone. Got that on your other post Beav as always in your tool box.
Thanks
John
Old 06-27-2002, 05:07 PM
good luck John
Kelli
WHO? WHERE?
Old 06-28-2002, 07:04 AM
Beav's Avatar
Not as old as Randy
Thanks
John
The strap wrench should work. The chips will be very small and the drill will be pulling them out towards the front of the engine. Any remaining behind the seal are easy to clean out with a rag and/or a spritz of carb cleaner. And just to be clear, that's silicone grease, not RTV.
Old 06-28-2002, 12:28 PM
I have used the strap wrench on a 2.2 engine and it worked good on the crank pulley.
Silicone grease works great ofr many things. I really like it. Use that also on my Anderson windows so they crank open easy.
Old 06-28-2002, 12:59 PM
CGLathrop
Question
IS this the same strap wrench that Sears sells??
Old 06-29-2002, 03:47 PM
Re: Question
I borrow this one from work. It is about 3' long, aluminum and the strap is about 3" wide. The strap is nylon. I had pretty tough time breaking loose the bolt on the 2.2 even with this. I cut an old pulley belt to fit in the grooves so that the strap didn't slip. I will most likely do the same with the old timing belt for the cam cranks.
