Old 11-07-2008, 12:21 PM
Michael Blue's Avatar
Michael Blue Michael Blue is offline
Sold. :'-(
Long time, guys...Winterizing.
Hey guys...Long time no see...
As you all know, I'm no mechanic, but I'm winterizing the SVX; oil change, coolant system flush and fill, fixing the windshield washer system, chasing down the road hum (I hope it's not a wheel bearing)...MAJOR pre-salt cleaning, etc., etc...
Stupid question...What is the fluid capacity of the coolant system?
I opened the radiator cap, reservoir cap and let it drain via the petcock on the radiator, and now adding a 50/50 mix back in, I didn't quite hit 2 gallons? Seems a bit shy to me, but I'm going to let it idle for a minute with everything open and see if it burps...If that's all she holds, we're good, but I thought I'd check.
Funny side note; it had been leaking a touch of trans fluid lately, so while I was under there I checked the "custom" external filter, lines, etc...NOTHING was more than hand-tight under there and it was all leaking all over the place...Even the filter wasn't even hand tight! No wonder I've had to add fluid to it somewhat regularly! If you have a swap by the guy that did mine, have a trusted (non-stoned) mechanic re-check and tighten everything, because it's probably about to fall right off your car, lol!
Anyways...Anything else you guys can think of that I should look into on this before winter, let me know...Thanks!
~M
'92 Pearl White LS-L Touring SOLD
4.44 Swap, trans cooler, trans filter, trans temp gauge
Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines
Raxles front axles
Old 11-07-2008, 01:09 PM
processengr's Avatar
Re: Long time, guys...Winterizing.
Rubbing some Sil-Glyde or equivalent into the door gasket/seals can't hurt...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 11-07-2008, 01:25 PM
cooling system w/ a stock radiator is just under 2gallons... so you should be good there... Everything else seems like it is in line for a good winterization. Gordon's idea about the door jam lube is a really good idea to keep the seals from icing together
Old 11-07-2008, 07:00 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
What is "pre-salt cleaning"? Giving the salt a good clean surface to adhere to?
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 11-08-2008, 06:08 AM
pgould66 pgould66 is offline
If your winters are like ours n NH, then recommend a set of dunlop sp wintersport M3s - they are great on snow and ice but still quiet and capable while cruising the highway at speeds on those nice days
Old 11-08-2008, 10:39 AM
Sold. :'-(
Not running dedicated snows yet, but I'll definitely keep them in mind for next year!
I've used Pirelli (W Sports?) before and LOVED them...There's something to be said for dedicated snow tires.
Now I have to go change the oil.
Thanks guys!
~M
Raxles front axles
Old 11-12-2008, 04:45 AM
Sold. :'-(
OK, got the oil changed, added some BRIGHT headlamp bulbs (damn, those are pricey!), sanded/polished the headlamp lenses, etc...
Now I have to track down the "thump!" in the front (on accel/decel...Strut?) and the "hummmmm" correlating to road speed (hope it's NOT a wheel bearing)...
OH, and find out why the washers aren't working (pump or clog) and get it sorted...
We're getting there...
~M
Raxles front axles
