Old 11-04-2008, 11:48 PM
Subie59's Avatar
Subie59 Subie59 is offline
94 SVX LSI Teal
Transmission fluid change - cleaning filters
Hi guys. I'm experiencing a slight torque bind so I am taking the car to the dealer to have the transmission fluid and the differential fluids all changed. My question is: Is it easy to clean the tranny filter and the magnetic tranny filter or does it involve major disassembly of the tranny to get at these filters. The service guy thought it involved major disassembly but I thought I read on here that it was simple....
Any quick comments before this morning's visit to the dealer would be appreciated.
Thanks
94 SVX LSI
2001 LegacyGT (daughter's ride now)
2005 Legacy outback XT (wife's car)
all stock and likely staying that way for now
1981 Datsun 280zxturbo summer toy
Old 11-05-2008, 12:25 AM
stiguy's Avatar
stiguy stiguy is offline
Re: Transmission fluid change - cleaning filters
na 20 bolts on the pan then 4 bolt on the filter
just be careful on removing the little pipe the goes over the filter takes some wilgeling to get it out but not to hard.
don't forget some sealent on the pan gasket its the pits when it leaks
Old 11-05-2008, 10:17 AM
Subie59's Avatar
94 SVX LSI Teal
Ok back from the dealer and, as expected, there is a list of things they are recommending. They have recommended some of these in the past but I thought I would get your ideas before proceeding with any of these.
1) Both outer axle boots need replacing. $400.00 parts and labour. I plan to go ahead with this repair because it is good preventive maintenance as winter approaches.
2) Transfer clutches binding on turns (This is the reason I brought it in.) (replace drop tranny) $1,200. I'm not convinced this needs to be done. I have had success with my Legacy by replacing the tranny fluid three times over the course of a couple months and using tranny additive.
3) Rear Separator Plate and Crank Seal Leak. $1000 (drop tranny) I'm not anxious to do this repair either. If I had a nice driveway I would worry about it but I don't care about the odd leak on the very old cracked ashphalt.
Your expert comments appreciated.
94 SVX LSI
Old 11-05-2008, 11:12 AM
ZMan's Avatar
ZMan ZMan is offline
Tranny Filter Replacement from how to docs.
Old 11-05-2008, 03:48 PM
kwren's Avatar
kwren kwren is offline
I would probably balk at the "drop tranny" big bucks 2 times.
My suggeston would be maybe do both things on one drop tranny. Most anyone would think of this except some shops. (Tacoma Subaru for one)
Old 11-06-2008, 06:07 AM
dcarrb dcarrb is offline
NON-expert suggestions:
If you're going to replace the CV joint boots, and plan on keeping the car for awhile, go ahead and have the complete axle assemblies replaced. The labor's almost the same. And try to find a good independent mechanic for a better deal.
If by chance your transmission also has a hard 1-2 shift and/or goes hunting between 3 and 4, could be replacing the throttle position sensor would solve these AND the minor binding. I wouldn't be optimistic about a fluid or filter change truly solving this problem.
dcb
Old 11-06-2008, 07:51 AM
Subie59's Avatar
94 SVX LSI Teal
Thanks dcb: I have had success with my legacy that was binding by changing the tranny fluid three times over the course of about two months and adding tranny conditioners.
I've told them to go ahead with the boots. I'd like to get them done before winter to keep the crud out....
94 SVX LSI
