Old 11-03-2008, 02:58 PM
dennyo dennyo is offline
Question 02 question
hoping someone can clear this up for me. the question is: what would most likely cause a known good 02 sensor to set a code indicating slow response? thanks dennis
Old 11-03-2008, 05:23 PM
XT6Wagon XT6Wagon is offline
Re: 02 question
Is it fullly seated, is the tailpipe clogged before or after it, is your SVX pouring raw gasoline across it?
Those are the main things I know of that piss off the newer Subaru ECU's in regards to 02 sensors.
Old 11-05-2008, 01:44 PM
Re: 02 question
thanks for the reply xt6.i'll have a look at those spots and make sure they are ok to rule them out. i'm also getting a pretty good leak on the rocker cover on the right side as well so when i change the gaskets i'll have a look around at the 02 wires thats the side i'm getting the code on. thanks for the tips. dennis
Old 11-05-2008, 02:18 PM
Re: 02 question
not positive but i believe if you are leaking oil onto the connection of the 02 sensor then that could cause the MIL to become illuminated.
