Old 11-01-2008, 11:27 AM
Bricopassion's Avatar
Bricopassion Bricopassion is offline
Help me from Switzerland....
Hello the "specialists SVX",
Since 1 month, I am owner of the SVX and today the engine does not start...
The lamp " chek engine" is lit....
What is necessary to make?
Electronic problem or fuses?
Thank you very much for your answers.
My English is not good…
Bye - regards
Bricopassion
Old 11-01-2008, 12:49 PM
Re: Help me from Switzerland....
Welcome to the site.
If you can provide some more details of what happened before it would not start, that would help. If there were symptoms before it would not start, those would help as well.
Old 11-01-2008, 12:54 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Does the engine crank and not start or just wont do anything when you turn the key?
Old 11-01-2008, 01:10 PM
Thanks for you answer.
Today, the car started (in my garage) and after 2 minutes I worked at the interior of my car but after 2 - 3 hours when I try to start the engine - more nothing...
The battery is good.
Disassembling of several parts to change the small bulbs of the instrument panel.
Check engine is lit.
Old 11-01-2008, 01:12 PM
Here's a couple easy to fix scenarios that could cause this:
Not enough juice from the battery. Make sure it's good.
Vacuum line is unplugged. Check your hoses. This may cause a CEL.
The engine is flooded. Give it some time to dissipate, crank it every so often. Despite being fuel injected opening the throttle does help.
Blown fuse. Remove the carpet kick panel to the left of the brake pedal, and check the fusible link box in the engine bay. This may cause a CEL.
I just saw your last post, I would really go over all your hoses. Check the big fat one under the air intake tube.
Old 11-01-2008, 01:16 PM
Yes the engine crank.
However it started after 1 week without rolling.
It is strange….
Old 11-01-2008, 01:23 PM
Thank you for all informations.
I control the fuses but tomorrow - it is 8:30 of the evening.
I inform you after all controls.
Thank you and regards of Switzerland
Old 11-01-2008, 01:40 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: Help me from Switzerland....
It is in "P" before cranking?
Old 11-01-2008, 01:50 PM
Yes it is in "P" before cranking?
SoCal LS-L's Avatar
Avalanche Alcyoneer
Since it only happened AFTER you disassembled the dash to replace the bulbs, you may have left a wire harness unplugged for your ignition switch or something else important. Id retrace your steps and make sure you didnt forget to plug something in.
Old 11-01-2008, 02:39 PM
Probable - nothing is connected....
- light roof
- switch heating seats
- switch heating rear window
- switch rear view mirrors
Beside the ignition key, there is an electronic box " Siemens".... (very small)
For what that is used?
Ignition Key Halo Light - bulbs?
On the whole I must change 6 bulbs...
Old 11-01-2008, 08:23 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Not sure, there are dozens of relays and control boxes on a SVX. Just take some time and go back through what you removed, making sure to pay attention to wiring. If it just happened right after you took that stuff apart, the answer HAS to be in there somewhere.
Old 11-02-2008, 01:04 AM
OK - I check all...
I find on the site "How to Read Codes"...
Very interesting.
Thank you at the author for all informations.
Old 11-02-2008, 09:53 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
No problem, if you find the cause, id like to hear what it was. Good luck!
Old 11-02-2008, 01:02 PM
OK - I found a problem with the handle of the shifting of speed.
The electric cable " ECO" is broken....
But I do not know if it is the problem…
See picture....
