Old 10-31-2008, 12:33 PM
nowelsy nowelsy is offline
92 svx lsl marine blue
Wink compression?
i was recently informed that i need to do a compression test on my subby i know how to do it and every thing but what i dont know is whats a good compression ratio that it should be sitting at compared to where im probably at? please do help cause i need to get my other motor down here and rebuilt if it's bad. and does any one know anything about the company in miami called ecutune.com the have excellent looking product and capapbillity to do what i want done to my motor trans and computers. but i was just wondering if any one has any feed back of them from personal exp. thanks for your help nowelsy!
Old 10-31-2008, 07:58 PM
wantafastsvx wantafastsvx is offline
Re: compression?
Your looking at i believe 150psi in each cylinnder if i recall correctly. And if there is any more than a 15psi difference then that is less thann ideal if i recall correctly. Been some time since i've dabbled with this. Im sure some of the resident experts will chime in if im off on the numbers but i believe that should be pretty close. And if you really are gonna do the compression check and have a digital camera i bet everyone on the network would greatly apreciate the extra few minutes to show your process so others can learn from ya
Old 10-31-2008, 08:05 PM
Re: compression?
Found this with a quick search on the site!
http://www.geocities.com/dsmgrrrl/FA...own.htm#WhyGet
Old 10-31-2008, 11:43 PM
kwren's Avatar
kwren kwren is offline
Re: compression?
Good information... Thanks
Keith
Old 11-01-2008, 06:46 AM
Re: compression?
anytime
Old 11-01-2008, 07:43 AM
Re: compression?
Great bit of info, for anyone looking to purchase the cylinder leak tester....
http://www.denlorstools.com/home/dt1...wn_tester.html
