Old 10-23-2008, 02:47 PM
legacyau legacyau is offline
noisy brakes
So i was doing some qtr miles the other night and in the braking area i was getting a rythmic drumming noise, i'm assuming its when they get some temperature in them.The noise increases the longer you keep pressure on the pedal but otherwise they are quiet in normal driving on the street. Could it be a minor crack or a crazed surface on the rotor that opens up when hot ? or glazed pads. Any ideas ?
cam
PS It did a 16.25 ET i thought it would be quicker than that
Old 10-24-2008, 09:37 AM
ShiuludeSVX's Avatar
Re: noisy brakes
cam
If you have time to pull the Rotors, then I would check for Warping.
Pretty simple, and just like checking the heads. Lay a straightedge of some sort across the surface, and look for daylight between the surface, and the straightedge.
Heavy car + Heavy Braking = wear, or warping.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
