too much engine oil for about0.8litre
does any guru knows that if i overfilled my engine for about 0.8litre of engine oil,what harm will it does to my engine,or if it ok,what should i do? thanks...
1992 SVX whitepearl 129,000km 2005 MAZDA3 red 38,000km 2001 HYUNDAI XG V6.3000 2003 TOYOTA PREVIA |
Re: too much engine oil for about0.8litre
Put car on jackstands. Remove oil drainplug. Quickly replace. Check level. Problem solved.
You don't want to have too much oil. A little excess won't hurt anything, but the SVX is already an oil pig, needing 6.5L of oil, so now you're at 7.3 or so, which is a hell of a lot. When you overfill the oil too far, it will get to the point that the crank is splashing in it as it turns, which will foam it, reducing effectiveness (air pockets all over the place).
If you don't want to get under the car you can just poke the dipstick in and out, wiping it off between pokings until you have removed the 0.8 liters.
Note, this procedure may take a little while longer. 7 or 8 years longer.
yeh,,,,i try do that,,,it did take me 7-8 years,,or longer.....
That's not too bad then, I've usually put about 6.5L in during oil changes, depending how long I let it drain for.
thanks,i guess itwont be too bad then,,less me some worry,yeh,last time my mechanic use about 6.5 litre too,cos two bottle of 4 litre each,left with a little less than half on the second one,,each time it was more than 6 litre...
Thread Tools | |
Display Modes | |
