Hit a curb, now havingl problems when turning
I accidently ran into curb and am now having problems when turning. My front passenger wheel was the only wheel that hit the curb. The car runs fine when going straight. I notice that when turning either to the left or right that the wheels want to lock up. It is more noticable when turning to the left. I took it to Firestone to have it looked at and they couldn't find anything wrong or broken on the side of the impact. I have read that it might be a problem with the transfer case. If so, would it be the one in the front or the rear? I'm thinking that I might need to take it to the dealer to diagnos the problem. Any idea what a rebuild would cost? My car is an AWD Lsi.
18" Centerline Forged Wheels, Falken Visa Z Rated Tires, Slotted/X-drilled Rotors, Steel-braided Brake Lines, Metal Master Pads. Future mods: Ram Air intake, hi-flow Cat., and drop springs. |
Re: Hit a curb, now havingl problems when turning
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
thanks.
Put it on an alignment rack. My bet is you knocked the castor angle back a couple degrees, likely indicating a bent control arm, strut, or knuckle. I'm slightly amazed that your wheel is fine though. 18"+any sort of impact normally leads to the rim being less round than it was before. Get them to throw it on a balancer to check just in case.
Thread Tools | |
Display Modes | |
