Old 08-17-2008, 06:28 AM
SVX_MY_BABY's Avatar
SVX_MY_BABY SVX_MY_BABY is online now
How do you clear TCU trouble codes?
I have a couple of "Previous problem" codes and want to clear them.
Old 08-17-2008, 06:35 AM
plantchick's Avatar
plantchick plantchick is offline
Mechanical 'L' plater ahead
Re: How do you clear TCU trouble codes?
When I looked around to find out the same for my '92, I found a note in the manual that said they couldn't be cleared - that they were stored as part of the memory.
Found it interesting, but don't know if it applies to all models, or only early ones.
Tania.
1992 Onyx SVX 184,500kms
Now with new and improved no leak steering!
No plants = no life on earth - so go forth and plant green things!
Old 08-17-2008, 08:26 AM
ShiuludeSVX's Avatar
Tania.
I would expect a recognition code to be "stored in memory", but not a trouble code that a sensor would create based on current conditions.
Disconnect the Negative Cable on your Battery.
Turn on your ignition, and turn on the Headlights. This will take only a moment to clear any residual voltage being held in any circuit in the car.
Re-Connect the battery cable, and all codes should clear. I expect the TCU will take a day, or more to produce a code, since it does this by watching the overall characteristics of how the car is running.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 08-17-2008, 06:42 PM
The TCU codes can be cleared by pulling fuse No. 14 marked AT in the fuse box under the dash. Middle row, end fuse nearest the door. Leave out for 1 minute
Old 08-18-2008, 03:27 AM
plantchick's Avatar
Wish I could remeber where I read it. Didn't make much sense to me either cause codes would build up. I thought maybe they'd cycle through over time - last in first out, kinda deal.
How many codes can the TCU store in 'past problems'? Will it only show one as 'existing'? I'm still trying to understand the relationship between existing and previous.
Old 08-18-2008, 07:04 AM
Thanks for that Harvey.
Suppose you could shed any light on my problem?
http://www.subaru-svx.net/forum/showthread.php?t=45802
