Code 37
Recently my 92 SVX has been intermittently running rough, usually when cold at idle, and more often when accelerating, I checked code and it gives error code 37 (lt sd o2 sensor). Could this be causing the problem? If so where is it located?
Thanks |
Re: Code 37
Located where the twin exhaust pipes come down from the motor and straightens out horizontally right below the transmission. Pretty easy to get to if you have a totally flat body or a floor jack and jack stand, and a couple of blocks for the rear wheels There are 2 one for each side and I think 37 is the one on the left side. It is easily changed because the quick disconnect electrical connection allows you to disconnect the 02 wire connector and drop it down, slip a big box end wrench over the wires and screw it out. May need some kind of rust buster, but probably not! Let us know if it works for you! Keith Last edited by kwren; 08-03-2008 at 12:48 AM. Reason: added more stuff |
Re: Code 37
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
Thread Tools | |
Display Modes | |
