Old 08-18-2008, 03:54 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
Re: multiple problems
Originally Posted by boipeba View Post
Quit smoking.
boi
ive honestly never used it ahah
although i think one of the PO s was a smoker
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 08-18-2008, 04:12 PM
kwren's Avatar
kwren kwren is offline
Originally Posted by tiv0 View Post
what do i check when the cigarette lighter is disconnected?
i mean, if the climate control and clock wont work when the cig lighter fuse is blown, then the climate control and clock wont work when the lighter is removed, will it?
sorry, idk much about this type of stuff
Of course it will... If a shorted out cigar lighter is the only problem. Disconnect the lighter and put in a fuse and see if that blows. if the fuse blows, the lighter is not shorted.
Old 08-18-2008, 04:34 PM
dromano's Avatar
dromano dromano is offline
Not too long ago my 92 cig lighter separated from the wires (at the bottom under the lighter housing), could be you have loose wires at that spot and shorting. Tough spot to get to. Someone suggested pulling the ash tray and trying to reach the wires. The wires may just need to be tightened.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 08-19-2008, 02:58 PM
tiv0's Avatar
svxless
j/w, can the cigarette lighter unit be removed?
i cant really disconnect it without it being taken out; even with the ash tray out
Trevor
Avondale, AZ
1987 BMW 325is
Old 08-19-2008, 03:13 PM
dromano's Avatar
When the wires separated from the lighter housing (female part) I didn't know this had happened until I plugged in the cell phone charger, there was no power light on the charger so I pulled on the charger plug and the lighter housing came out with it. Try twisting the lighter housing, it may come loose. Hope the wires are still connected.
Old 10-01-2008, 08:32 PM
tiv0's Avatar
svxless
its been a while that ive been experiencing this issue with my climate control, clock, and cig lighter not working
and after multiple attempts at removing the cig lighter, all failures, i decided to take my car in to the dealership (with the SVX mechanic)
turns out that a few wires under the drivers side vanity dash were frayed and shorting out
they cleaned it up and everything's all good now
just thought id fill everyone in, whether or not this ever happens to you
Trevor
Avondale, AZ
1987 BMW 325is
Old 10-01-2008, 10:02 PM
Thanks - that is good to know. I would have guessed that it could have been the sun visor as well.
Old 10-02-2008, 06:57 PM
tiv0's Avatar
svxless
you know, its funny you mention that
i tried doing the "$2 visor fix" and they worked fine for about a day...and then started sagging again
so i use a spare dogtag i have lying around to hold it up
anyway, i noticed, after i got the car back that the dogtag i had up there was gone and my visor was sagging.
so he must have checked that
so now that you mention it, it might have also been a visor issue, because idk for sure how well i had those wires soldered back together
Trevor
Avondale, AZ
1987 BMW 325is
Old 10-02-2008, 07:12 PM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
The problem with the "$2 fix" is that the piece you put into the plastic to "fix" the sagging doesn't grip the other end. I'm currently toying with different fixes that are a bit more effective. I have completely stripped an old (bad) visor to experiment. Keep an eye out for a thread about my findings.
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 10-03-2008, 02:26 PM
tiv0's Avatar
svxless
will do
thanks
Trevor
Avondale, AZ
1987 BMW 325is
Old 10-03-2008, 06:13 PM
kwren's Avatar
they do sell new ones and they don't sag
Old 10-06-2008, 04:03 PM
tiv0's Avatar
svxless
for quite a price too...
Trevor
Avondale, AZ
1987 BMW 325is
