multiple problems
simply put, here are my problems:
-clock does not work/light up -climate control does not work/light up -all windows except drivers front will not roll down i noticed all of this today while driving the car after letting it sit for a week the car drives fine so im assuming its just something electrical? i figure always check the easiest, most obvious things first, so i changed out some fuses, but still have no luck in anything being fixed. these are the fuses i changed: -10A clock (under hood) #25 -10A A/C (under hood) #33 -10A illumination brightness control (under dash) #9 -15A heater fan (under dash) #20 -15A heater fan (under dash) #21
Trevor Avondale, AZ 1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13 1992 LS-L Claret 178k totaled 10/26/09 1987 BMW 325is 60% of the time it works, every time |
Re: multiple problems
maybe you fried some wires? I would run a multimeter on the plugs for those things to see if they get any power.
Do you have an aftermarket sound system/head unit? Could be some wires in there shorted out??? Is your cigar lighter working?
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD 92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD 92 Teal SVX LSL lowered with Konig. SOLD 92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone 94 Red SVX L FWDwith LSL Leather Interior. SOLD 92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD 95 Polo Green........With Trany Problem. GONE Almost complete Rear Wheel Bearings Job with Pictures in my locker My Locker http://www.subaru-svx.net/photos/user.php?pearlm30 |
new aftermarket radio/cd player was installed some years back. and just recently i had an iPod playing system installed
and no, my cigarette lighter doesn't work anymore either
If cigarette lighter fuse is blown it will affect clock and climate control--worth a check. Also double check window lockout switch just above window controls on driver door--it disables all others. Just a couple of thoughts.
The Cig lighter fuse is probably blown. Happened to me that is most likely the problem. Took me pulling all the fuses to find that its a 20 AMP (yellow) one.
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
that was my problem why does the fuse for the cig lighter effect the clock and climate control?
I wish I could tell you but I remember when it happened to me and I was told to pull out the multimeter :P but its known now about that lighter. Glad its a simply cheap fix huh?
i shouldve checked that to begin with windows work all problems solved thanks
Would be easy to overlook!
Keith |
How do ya think I said to check it--I have been there and got the T-shirt--couldn't believe when I did it
im bringing this thread back up because after about 2 weeks of replacing the cigarette lighter fuse, its blown again.
i put in another fuse, turn on the car, and it pops after a few seconds. so i assumed there was a shorted wire somewhere, and took the car to this guy i know who works for a car audio/stereo company called Inphase. (he installed my electric start/door lock/unlock switch, and i was wondering if my problems were caused somehow by the wiring he had done for that in the first place) but after looking at it he cant seem to find the problem he believes that maybe my cigarette lighter *switch* may be bad any suggestions? as of now i cannot use my A/C climate control or clock
I would disconnect the cigar lighter and see what happens in case there could be a short in the lighter itself.
Keith |
what do i check when the cigarette lighter is disconnected?
i mean, if the climate control and clock wont work when the cig lighter fuse is blown, then the climate control and clock wont work when the lighter is removed, will it? sorry, idk much about this type of stuff
Quit smoking.
boi |
