Synthetic oil or regular oil and filter questions.
#1... If synthetic oil makes the car leak oil, would switching back to regular motor oil slow the leaking down. Talking about the rear main bearing seal leak.
#2... Has anyone opted to change the oil filter more frequent instead of changing the oil. Maybe every 1000 miles? Thanks in advance for any input. Keith |
Re: Synthetic oil or regular oil and filter questions.
i didn't know about synthetic making the car leak oil...i've heard about using synthetic and the car burning oil..
but i dont think changing the oil will slow a leak~
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
Has anyone considered just changing the oil filter more frequent and not changing the oil?
I am considering changing the filter every 1000 miles or so miles and see how the oil does. I notice when changing oil the oil in the filter is always much dirtier than the engine oil on the dipstick. Keith |
I use synthetic oil and the porche filter and change them both around 5000 miles
I was told by a race car driver that you can use Mobile one synthetic every 12000 miles but make sure to change the filter every 3000. I never tried it but it sounds like a good idea.
You can always add a little brake fluid to help swell the rubber on your rear main to slow the leak. (I am asking for it huh) I haven't tried it, and don't think I ever will, but it is just something I have heard a few times over the years. This is typically ok from what i have read, and consider it to be good advise (unlike the above bit).
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." |
Thanks, Keith |
I will start off changing the filter more frequent than 3,000 miles and see how it goes. Maybe 1000 miles first... (today) Then 2000 miles next...(Three weeks from today) then get to the 3000 schedule. *[/SIZE]Has anyone noticed the sharp increase in the price of synthetic? Don't know how synthetic, not a blend, is made, but maybe it is somehow related to the price of a barrel of oil? Could maybe the "greed factor"? Keith |
Synthetic is just that--it is synthesized instead of refined. This creates a more uniform product that doesn't have certain molecules in it that you'd rather it not have. The much wanted missingness of these molecules makes it more stable at high temperatures. It also makes it easier to control the oil's viscosity at a wider range of temperatures.
As for cheesy repairs of oil leaks. The bolts on the valve covers bottom out stopping you from getting any more pressure on the gaskets as is. If, however, you wanted to stop them from leaking for a while with an easier job than replacing the gaskets....adding washers between the bolt head and bolt seal would do the job. You can also replace the intake cam plugs without getting into the timing set. These two things will greatly slow the oil leaking on an eg33 for the lazy man. Quote:
I did the valve covers gaskets and cam plug and cam seals but the rear main is leaking a bit.
That is my concern now. Keith |
I just got my order of 11 of those @ $6.99 ea... no shipping and no tax yesterday from PA it was, I think. That was my inspiration for this "change the filter" adventure! Keith |
Could you explain the access to the cam plugs. From what I have looked at it looks like the cam pulley and back cover come off to get at the cam plug. Dave
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
What i would call the cam seals are behind the cam pulleys. What I call the cam plugs are on the intake cams--which don't have pulleys. All you have to do is take off the ends of of the timing covers and you can pop off the old cam plugs grabbing them with a pair of channel locks and then tap in some new ones.
edit--what i call cam plugs are black and they are just that plugs..they don't have a friction surface...they just plug the hole and you wouldn't think they would leak but they do..big time
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 07-26-2008 at 08:01 PM. |
Purolator PremiumPLUS L30165 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 07-26-2008 at 08:22 PM. |
