Old 07-24-2008, 09:54 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Front end creeking
I've noticed the front end on my car most noticeably the left front sounds like a creeking pirate ship when turning forward or reverse at slower speeds.
I also notice when going over speed humps ( I have a few at my apartment) that something sounds like it's loose and squeaky in the same area. Could my strut be bad or the mount?
1995 Subaru Svx L / AWD
Old 07-24-2008, 10:38 AM
jpolchlopek jpolchlopek is offline
Re: Front end creaking
That's incredibly weird -- I've been noticing this exact same problem over the past couple of days.
Occasionally, when I move forward or backwards from a standing stop, you will hear that low pitched "CREEEAAAAK". The pirate ship analogy is a perfect way to describe it.
It seems to be related (in my case, anyway) to the wheels, as it only happens at very low speeds and right before/after coming to a complete stop. Would the struts or springs be affected at that low speed?
Old 07-24-2008, 11:36 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Re: Front end creeking
Are you guys running polyurethane bushings? If so, the grease probably dried up and needs to be regreased. That's currently the issue I have with my car, but I'm too lazy to regrease them
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 07-24-2008, 01:09 PM
Strut mounts perhaps?
Old 07-24-2008, 08:15 PM
msvx95's Avatar
It's just a phase
I'm running the standard bushings, whatever they are made of...haven't regreased anything, but at slow speeds, how can struts/strut mounts really make noise and move around that much?? I am driving on flat ground too...weird
I can check to see if the strut is leaking, but what's a worn mount look like?
Old 07-24-2008, 08:23 PM
redlightningsvx's Avatar
Collision Refinishing Tech
brakes maybe?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 07-24-2008, 08:25 PM
msvx95's Avatar
It's just a phase
I have brand new drilled and slotted rotors recently installed a month ago...they've been great, no issues.
Old 07-24-2008, 09:28 PM
SuberNatural SuberNatural is offline
I have the same problem but i think it may be my swaybar link
Old 07-25-2008, 10:26 AM
msvx95's Avatar
It's just a phase
The noise is most noticeable when I turn the steering wheel while going slow.
Old 07-25-2008, 10:40 AM
Have you checked your tie rod ends?
Old 07-26-2008, 03:35 PM
msvx95's Avatar
It's just a phase
I can push down on the left front fender and hear some type of noise...when I push down on the right front, the noise is still present on the left front...kinda seems like a strut issue now.
How do you check tie rod ends? Check if they are loose? WOuldn't the car handle funny?
