Old 07-16-2008, 09:28 PM
togan07 togan07 is offline
Power Steering pump is gone...
Wondering the cheapest place to pick one up for my SVX? Or if anyone is parting out their SVX on here that'd spare it? So far I found a couple for $99 which isn't bad at all, but seeing if I can save even a few more bucks anywhere.. thanks.
BTW
This is my first post/thread of I'm sure a ton more. I love my SVXs =)
Old 07-17-2008, 06:03 AM
dcarrb dcarrb is offline
Re: Power Steering pump is gone...
Greetings.
If you can get a reman power steering pump for $99 (are you sure about that?), that's the way to go. No sense paying half that for something that might fail tomorrow.
dcb
Old 07-17-2008, 06:59 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
are you sure its the pump? the seals on my rack are now so blown that it feels like i don't have power steering at points...
- John
Old 07-17-2008, 07:12 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
My steering feels good, but god does she squeal... On cold starts, warm starts... what is the deal. I just changed the fluid a month or so back, and I also put on new belts.... Got rid of the AC squeal, but now my steering does...
Sorry for the hijack, just wondering if mine could be going because of the mad squeals?
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
Old 07-17-2008, 09:42 PM
corncrasher corncrasher is offline
Check the bearing in the idler pulley.
The pumps are easy to rebuild and you can get any of the parts you need for it from subaru. If you buy the parts from www.subaruparts.com and rebuild it , it is cheaper than a reman and will be better quality. Cheap reman equals junk.
Old 07-18-2008, 11:01 PM
mysvxrocks's Avatar
I have no idea how to do that. Nor do I know which parts I would need... And help?
D.J. McPhee
Old 07-19-2008, 04:03 PM
There is info on the pump in the how-to documents at the top of the page
Old 07-19-2008, 08:49 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Squeal?? Actually I have never heard a power steering pump squeal. They usually sort of growl. A squeal is generally belt related. Check the tension of your belt, check the idler pulley and put some belt dressing on the belt and see if you still have the sound.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 07-20-2008, 01:45 AM
mysvxrocks's Avatar
How tight does the belt need to be exactly? It REALLY squealed at me today.......
D.J. McPhee
Old 07-20-2008, 09:07 AM
The only squeel I have heard is the bearings going out on the AC clutch. You might check that. You say the steering is good, but it squeels. It is hard to tell sometimes where the noise is coming from.
Old 07-20-2008, 11:13 AM
mysvxrocks's Avatar
Is there a write up somewhere on how to check that? I dont even know where that is. I assume its one of the parts the belt is running on, but I dont know which one. Its getting really annoying, it does it every time I start my car
D.J. McPhee
Old 07-20-2008, 12:09 PM
Does it stop after a while? Do you know where the AC Condensor is? It is the belt that comes up the higest on the engine. It is probably the one making the noise.
Old 07-20-2008, 02:25 PM
mysvxrocks's Avatar
Yeah, it squeals sometimes on start, then the first time I crank the wheel over. After that its fine, just does it the frist and sometimes second time I turn. So if it is that one, how do I fix it?
D.J. McPhee
Old 07-20-2008, 03:43 PM
That sounds like steering if it does it when you turn the steering wheel. I would try tightening the belt a little and using belt dressing and see if that helps. If it is the AC clutch, it would squeel before you even touched the steering wheel.
Old 07-20-2008, 05:16 PM
mysvxrocks's Avatar
Well, really it depends. The last couple days, its done it when I first start the car for a few seconds. Then it does it again as soon as I touch the wheel. When I get home I will try to tighten the belt, and I will put some dressing on them as well. Hopefully that will help. It is quite annoying when it does it... makes an awesome car sound like crap
D.J. McPhee
