Old 06-27-2008, 04:25 PM
ABS code #9
I have the abs light on in the dash. Checked the code and getting a #9. This could be a number of things. Does anyone know if I can take my car somewhere and have my ABS system hooked up to a device that can more specifically diagnose what is going on. Also would it be safe to just remove the ABS fuse under the hood thus disabling the ABS and brake without it. The way it is now when I drive the ABS unit under the hood continues to run after the engine is shut off. I just disconnect the battery so I don't drain it down. Any knowledge on this appreciated.
Mike
95 Pearl Blue L
Old 06-27-2008, 04:41 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: ABS code #9
I had this happen once and, from an earlier post suggestion, just used my knuckle to give a swift tap to the unit and it shut down. Luckly for me, it's never come back. Do little search, you aren't the first.
Gene
Gene and Ben
