Old 06-09-2008, 11:02 PM
Marcus Marcus is offline
influence of gear swap on the odometer
Hi,
there is a lot of talk about 5speed swap (thats why I am interested) and differential swap to 4.44 (for max exeleration) which makes me think how this does influence the odometer speed indicator.
As far as I understood the revolution sensor sits in the trany measuring on the output side (naturally).
The revolution measured are translated to speed, taking differential ratio and tire size into account.
Therefore if I change tire size or differential ratio the speed shown at the odometer cannot be accurate anymore, can it?
If I am right does anybody know how to compensate for it (in order to regain right reading)?
Thanks!
Marcus
Old 06-09-2008, 11:30 PM
Originally Posted by Marcus View Post
Hi,
Thanks!
Marcus
There are two speed sensors Marcus, the speedo uses the front one, that is run off the front right axle stub, that rotates at wheel speed, so the final drive ratio change won't affect it. Only tyre size.
