Old 06-08-2008, 11:10 AM
black beast black beast is offline
Back Road Blazer
Send a message via AIM to black beast
Unhappy Fuel system help.
Do we have an in tank fuel pump?
The FPR, where is that in the engine? can I see it easily?
I changed my fuel filter and my car ran good for a few days, it has started to act dumb again, like it did before the fuel filter was clogged, choaked for gas. When I replaced the fuel filter it ran good again. So maybe it is not just my fuel filter. Maybe my bad filter hurt something else...
If someone could do a How To on the FPR and the fuel pump, I know I can do this I just dont know how. Thanks alot!
-Chris
'94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc.
Old 06-08-2008, 03:48 PM
Speedklix's Avatar
Locker Link Solution
Has the fuel pump ever been replaced while in your charge?
..and how many miles would that have been?
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 06-08-2008, 05:19 PM
Back Road Blazer
Fuel pump has not been replaced... car has 144,00ish miles on it. I am taking it to subaru tommorrow and gunna find out what wrong with it, and how much it costs to fix, and if it is too much, then I might be gettin a new(er) car. I have dumped so much mone into this and I can buy a stock WRX, 2002ish and have money left over to mod it.
I havent decided what I will do with it. Dependes on the cost to fix it.
-Chris
Old 06-08-2008, 06:34 PM
There is a How-To Document on fuel filters. It is here, in the How-To Docs under engine.
Old 06-08-2008, 06:41 PM
The fuel pump is located underneath the access plate which is below the trunk carpet. I should have a photo to explain. Its super easy to get to and you should be able to do it yourself.
