Old 06-03-2008, 07:47 PM
Treppiede Treppiede is offline
Oil Pan Leak
Fellow SVXers,
Time has come for me to remove my oil pan, cleaning everything and reinstalling it with a new gasket/sealer.
I have yet to remove the oil pan, and I'd like to have everything ready.
Do our cars have a gasket or do they use a high-temp sealant?
If it's sealant, which one do you guys recommend?
Thank you in advance,
-Walter
1995 SVX Green - now 5spd! ..::|SOLD|::..
1991 Talon TSi AWD (~400 whp pump gas)
1993 Civic CX Hatch (daily driver)
1999 Ducati 748S (built 996 engine)
Old 06-03-2008, 11:53 PM
Originally Posted by Treppiede View Post
Fellow SVXers,
-Walter
No first hand experence Walter, but this has.
http://www.subaru-svx.net/forum/show...creen%2Cfilter
Ps. Hows the Duck going?
Old 06-04-2008, 12:02 AM
Considering it is a 5mt I doubt he need worry of the auto oil pan.
The Eg33 takes a sealant not a gasket for the oil pan. Suggested to use Subaru triple bond... I think thats what it is called. I personally use Ultra Black sealant. The pan can be a bugger to get down esp if the dipstick is stuck well. Not to mention the very tight clearances for the rear bolts due to the subframe. When the pan is down... Carefully use a razor to remove all old sealant from the engine block. Then I suggest a wire wheel to remove the sealant from the pan itself and its grooves. Once all is cleaned up and there is nothing lingering in the bottom of the pan. Lay a thick bead, but not too thick, toward the inside edge of the pan. Replace the two O-rings on the dipstick tube and reinstall... Its not so bad but can be nerve racking and time consuming. Good luck Walter
Old 06-04-2008, 12:14 AM
Good luck Walter
Good thinking Batman.
Old 06-04-2008, 08:51 AM
Harvey, thanks for the reply, I guess it's my fault for not specifying the oil pan I was talking about. The Duc is good, still down in Miami (I moved to Atlanta for work 1.5 yrs ago). I am getting another set of cams installed then I'll bring her up here, hopefully in July!
Tom, thanks for the detailed answer. The Ultra Black sealant you use is the typical one from Permatex, correct?
Thanks for the info, that's all I needed before jacking up the car and getting to work!
-Walter
Old 06-04-2008, 09:18 AM
-Walter
Yes but Permatex makes several sealants... Ultra Black is the one you should be looking for
Old 06-04-2008, 02:08 PM
Absolutely, that's what I meant.
Thanks Tom,
-Walter
Old 06-04-2008, 04:20 PM
redlightningsvx's Avatar
Collision Refinishing Tech
The Subaru techs at works use the Fuji triple bond sealant because they say once it's on it's like cement.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-05-2008, 07:02 AM
And I disagree... Check out the seperator plate on a 94-97... I can almost guarantee that the triple bond is toast and leaking....
