Old 06-04-2008, 12:09 AM
Originally Posted by Landshark View Post
yeah, i wish mine had one. mine got locked up (horn fuse blew, shiftlock on same fuse - found that out later ), so i popped the access cover, and promptly managed to strip the screw to the shiftlock with the POS Subaru screwdriver that came with the car.
All you would have had to have done is remove the cover where the shift lock button was on the older cars and use a rod (hey that neat screwdriver would have worked) to push down to release the shift lock manually... Problem is, not many people actually know that
Old 06-04-2008, 12:11 AM
Actually not that at all. The Japanese were smart enough to know that the Aussies would not be able to figure it out----so they didn't put it on.
Lee
Didn't think of that Lee...
Probable didn't think we could polish the headlights or work out how your "mouse trap" seat belt goes.
Old 06-04-2008, 05:53 AM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
im unfortunate enough to have to use the shift lock button EVERY time i want to change gears; brake on and everything
i believe someone said it was possibly a solenoid problem?
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 06-04-2008, 06:56 AM
the newer ones have a screw you had to loosen/remove (i forget) first, once the cover is off.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 06-04-2008, 07:26 AM
Its not very common for the solenoid to go bad... More than likely the controller which is mounted next to the parking brake under the center console. Best way to test for sure is to test for power to the solenoid first... If there is power, the solenoid is bad... If there is no power, replace the controller.'
Old 06-04-2008, 07:27 AM
Maxo's Avatar
Maxo Maxo is offline
What are the benefits of the shift lock button again?
...So that next time I bring my left hand down to the shifter too, in attempt to put the car in gear, I can smile instead of shake my head since I'm in my other non-svx car.
