Old 04-15-2008, 10:58 AM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
Good Vibrations
When I'm at a light, my passenger side seat belt has a tendency to vibrate. At idle and when changing the radio station. I first I was like WTF. At first I thought it was a speaker cover. Untill way later, I put my hand on the seat belt clicker thing.
To fix it I can loosen a little it up right? I Think its attached the frame seat.
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 04-15-2008, 02:28 PM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
Whoah mine has done the same thing for over 5 years but I've never said anything about it! I even took the passenger seat out and detached the bracket, put some rubber washers in there, and reattached. To maybe cushion the connection between the seat belt and the frame. Didn't help.
Two things work (other than possibly a new assembly, not sure what the cause is though).
One, I used to drive around with the passenger seatbelt fastened. This eliminates the rattle. Either it is just enough tension pulling on it, or the rattle is something inside the buckle and when it is fastened it can't rattle.
Two, I started just keeping my Wedgie cupholder in place all the time. The position mine goes is such that part of it fits between the seat belt bracket and the center console. It is Wedged in there tight, and again, no rattle.
Since the car didn't do this in the beginning, I'm assuming that part needs replacing - it's not a matter of something being loose because I've taken everything apart and back together a couple times to try to fix it. Not really an issue with the Wedgie though, and I do have a new seatbelt on hand for my manual conversion if I ever actually get it done.
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
