Old 02-15-2008, 12:41 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Engineers and Physicists on the Network?
With what appears to be a "critical mass" forming on the EG33 performance front, I was wondering just how many members of the network are card carrying engineers or physicists (yes, OT and YT, I'll also accept "by genetics" and "I would be if I had wanted to waste 4 years in college")?
1. SVXRide - BS in Mechanical Engineering with 1+ years of graduate work in Material Sciences and a MS in Technical Management
2.
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-15-2008, 12:48 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
2. LetItSnow - BS ME, designing transfer case internals to pay the bills.
Old 02-15-2008, 01:03 PM
94SubieSVX's Avatar
OOC for a while
3. 94SubieSVX - Working on my degree in Applied Science then going for Electrical Engineer
bLAh
Old 02-15-2008, 01:13 PM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Does Software Engineering count?
BS in MIS, but now a software engineer by trade.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 02-15-2008, 01:37 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I was two years into Biomedical Engineering before i switched out... does that count?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-15-2008, 02:11 PM
RSVX RSVX is offline
Network Design Administrator
Network Engineering?
Life is a game. Play to win.
Old 02-15-2008, 02:42 PM
SVXRide's Avatar
Yep, software engineers tend to have a good "systems" approach to technical problems. Sign up!
-Bill
Old 02-15-2008, 02:43 PM
SVXRide's Avatar
Yep, sign up!
-Bill
Old 02-15-2008, 02:45 PM
SVXRide's Avatar
Do you always look at the "larger picture" when faced with technical problems? If "yes", please sign up!
-Bill
Old 02-15-2008, 03:03 PM
shotgunslade's Avatar
4. Shotgunslade - PE in 10 States; Mechanical Engineer specializing in HVAC design and energy efficiency in large buildings
Old 02-15-2008, 03:31 PM
Wikedjuggalo's Avatar
Rebuilding
I have a question for all of you in the computer Tech world. I am after a Associates in Networking and a BS in Software Engineer. Possible a BS in Networking but what is the work like for any of you out there that do this. My love falls in 3 things, Brittany, my SVX and Computers. But Anyways would a degree in these yield a good occupation?
Old 02-15-2008, 03:35 PM
5. Svxistentialist - B.Sc. Physics, Chemistry, Maths.
Not strictly engineering, but scientific anyway
Old 02-15-2008, 03:46 PM
SVXRide's Avatar
I've always consider Physicists as close cousins to Mechanical Engineers!
-Bill
Old 02-15-2008, 04:07 PM
no engineer, but who would want to drive a train anyway
They do call me professor though
Old 02-15-2008, 06:33 PM
SVXBart SVXBart is offline
6.SVXBart - M.S. in Geomorphology.
Bart
