What air filter set up is every one using.
As part of fixing my air intake problem I have been driving (short term) with out the air box in the gaurd. What has surprised me is that the car revs out better etc with out it. The car has more power. This has lead me to think what power can be gained by developing a better air filter system.
So whats every one using. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
Stuffed up and posted twice but here is a articale that deals with our Air intakes but on a WRX.
http://www.autospeed.com/cms/A_1605/article.html
i'm running a cai with a green cylinder filter from dayles
Stock thingamabobber with a K&N filter. Although I've heard the oil in those filter can foul your MAF in the long run, and they don't clean the air as well as paper filters. I didn't notice any appreciable difference in performance.
Dayles Cold air piping and a HKS race foam filter, i think it feels faster...
-Chris '94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc. |
Running a fender-well intake of my own making with 3" aluminum piping and a cheapo Autozone filter. (not the one with the screen on the end...ewww)
Seems to work well. Not as pretty of a sound as just a filter mounted on the MAF, but it seems to keep its power better throughout the day. I imagine it has something to do with taking air from outside the engine bay.
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
I have a Kool air filter (K&N) in the stock box. Resonator delete, and modified air box tube. Insulated snorkel w/ some 3M silicon foam and bonded aluminum stuff.
I know the filter isn't worth much, but I had the oil and cleaner sitting there doing nothing so I just bought another filter to use the stuff on. My exhaust muffles any intake noise I may have gained with the mods.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." |
I have purchased a gauge as mentioned in one of the Auto Speed articles to measure the negative pressure at the different positions on the intake. This should tell us exactly what we are dealing with with soem solid numbers. It would be good to do a dyno as well but not sure about that.
Tony
The new gauge has arrived to measure the negitive boast on the SVX intake system. I plan to measure the following :-
Loss in airbox (inside guard) Loss across airfilter also for different types of filters. Loss from MAF to throttle body. and depending on what I find, the loss in the MAF unit. I will let you know what I find when its done. Tony
Here is what it looks like.
A very worthwhile project Tony.
The instrument you have purchased appears less sensitive than I would have expected to be required for accuracy. Don’t forget to adjust the zero. It will certainly be interesting to see the results with readings across each likely point of restriction. How are you going to measure loss in the air box? Good one, Trevor.
Why lose the stock airbox?
I have been suggesting in fender cone filters for a reason.
- The stock airbox is a "cold air" already. it feeds ambient air from the fender already so a CAI is not going to improve air temperatures. + the reason i suggest an in fender cone filter is that it will draw the same ambient air as the stock air box... BUT... it smooths out the intake track. The stock airbox is like merging a 6 lane highway down to 2... Its gonna slow velocity down. It creates "dead spots" in the intake which during high rev's and high flow will become an obtrusion. The in fender with a cone filter creates a smoother track for the air to flow in and decreases turbulence. Thats the reasoning behind them for me. Tom |
I picked up a K&N panel filter from a guy with an STi who opted for a short ram setup.
The key? Don't over-oil 'em! Another guy I know who has a WRX put a little too much of the red stuff on, and it coated the MAF nicely, which was most evident to him in that his fuel economy was absolutely destroyed.
Disclaimer: The above post is on the internet. |
Pressure Gauge.
Tony, please consider.
The pressure gauge you have purchased appears to have only one point of connection and therefore measures pressure above atmospheric, which means that without modification it will not do the job you have in mind. Unless the intake airbox is placed at an advantages position and the car is in motion, there can be no positive pressure of any consequence within the intake manifold. Your experiment requires the measurement of pressure developed across a restriction from inlet towards outlet, rather than against atmospheric. This could be achieved by mounting your gauge within a rigid transparent container so that it can be viewed, with the existing inlet brought to the outside, and with a second connected to the interior of the container. This arrangement could provide two connections and a means of pressure measurement between the inlet and outlet, of any anticipated point of restriction within the manifold, at various engine speeds and load. Alternatively you could use a sensitive vacuum gauge and measure the negative pressure at the point of entry and exit of the restriction and make a comparison. However this method would not be as efficient.
