OT: Outback warning lights
A few days ago the CE light came on in my wife's '05 Outback. I was...surprised, to say the least. The cruise control light started blinking at the same time. Both remained that way until I read and cleared the stored codes. There was a 'too rich' code stored for each bank. I cleared them to see if they came back, and so far they haven't.
The CE light I think I understand. A certain fault occurred multiple times, or was severe enough, that the light stayed on to show that it was storing a fault code. The cruise control light, however, I'm not so sure about. Was the light flashing to tell me that cruise was disabled because the engine was in a limp-home mode? That's my guess so far. Thanks.
Cruise control by vacuum lines and a little cylander on the back of the engine bay. Check to make sure no hoses popped off, if so fix it and problems hould go away. I'd clear the codes to see if they come back, sometimes they're just flukes.
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! |
So does the cruise work? Did it work when the light was on?
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." |
The current-gen Legacy and Outback have throttle-by-wire setups. There is no vacuum line to the cruise control. As a matter of fact, you can't even see the cruise control because the throttle is only opened by one servo. Yes, I cleared the codes to see if they were 'flukes.' I suspect they were. What I want to know is why the cruise control light was blinking on the dash. I suspect it was because the ECU disabled cruise - it didn't work while the light was blinking.
The Cruise Control light flashes when there is a new code registered in the newest Subarus. It does disable the cruise control, as well. There is nothing wrong with that system.
Disclaimer: The above post is on the internet. |
That tells me I should bring my OBD-II code reader on every road trip from now on, just in case there are any more 'flukes' and I'd like to use my cruise control.
Svx???
And how does this relate to our SVXi? Maybe because of the original poster. Anyone else would have been moved to the appropriate NON SVX thread.
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
the cruise control light will also blink if you run it out of gas.
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty - Sold 07/31/2011 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles |
Seriously?
yes. and it believe the cruise light will flash if you let the battery drain. i am a bad new subaru owner.
right back at you.
I had no idea that the cruise control light was used to warn the driver about so many other things.
agreed! i'm sure i will encounter what else it's used for in the near future and i'll be sure to post up.
Fine
Lee
