Old 01-17-2008, 01:44 PM
Ownbot's Avatar
Ownbot Ownbot is offline
I'm the anti-do-gooder
Timing Belt
My SVX has 155k on it and it's unknown if the timing belt has ever been changed. Should I be concerned with it snapping or not? I have yet to hear about the belt in a EG33 ever snapping.
Old 01-17-2008, 02:02 PM
You don't say how long you have owned the car, how many miles you have driven it, but at 155K it is due a new timing belt in the normal run of things.
Normal replacement interval is 60K miles. If it has had a replacement at 60K, and was not in your ownership at that time so you are unaware of the replacement, then since that time it will have done more than another 60 and is now due again anyway.
If it was never changed then it is more than double the recommended mileage, and a replacement will be urgent.
If it breaks the valves and head will not be damaged because it is a non-interference design. However it will probably break or damage the plastic covers, and make the replacement job more difficult and costly.
It is more likely to jump a tooth and leave your timing all wrong, but it could break.
At your current mileage you should replace the belt and the idler pulleys and the tensioner. While it is off you should also attend to any front seal leaks [there usually is a leaky seal or two] and you should also replace the water pump. You should also consider replacing the oil pump while you are at it if you want to do a thorough job.
Old 01-17-2008, 03:08 PM
kwren's Avatar
kwren kwren is offline
timing belt kit
This kit is a buy it now thing on ebay. I ordered it a while back and found these people to be "good" people.
might look into it. It even includes a new waterpump.
Timing Kit Contains the following:
(1) Timing Belt (13028-AA120)
(1) Timing Belt Tensioner (13069-AA070)
(2) Timing Belt Idler (13073-AA150)
(2) Timing Belt Idler Sprocket (13085-AA020)
(1) Water Pump NEW
The link... http://cgi.ebay.com/ebaymotors/1992-...em230211710809
Take care,
Keith
Old 01-17-2008, 06:03 PM
gsodonis's Avatar
gsodonis gsodonis is offline
Good kit
I can vouch for the kit - nice quality parts. The waterpump is even a Prestone brand - made in the USA. With 150K (exactly what I had) on the odo, don't even think about replacing only the belt and the tensioner. All four of my idler pulleys were all very noisy and dry as a bone.
Old 01-17-2008, 06:25 PM
(1) Water Pump NEW
Take care,
Keith
Top notch Keith.
These kits are really good value.
