back in stock
Ok guys,
I know there are a good # of people waiting for stage 1 and stage 2's to be available again. I don't know how many of those are on the network but to try to answer the questions about when I will have stock again... the answer is 2 weeks. I had ordered a small batch of the prior generation of memory adaptors to minimize the out of stock time but I got the new design done soon enough that I cancled that order and replaced it with the new design. In 2 weeks I will have stock again. |
New design? Whats different about it?
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
yeah, what AF said
-Bill
If it makes coffee, how much is the upgrade?
really, what does it do? I'm having an issue which may be stage 2 related, and curious about any info on changes being made. Thanks
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
what appears to be the issue with your 2v7? -Bill (getting ready to install his 2v7...)
there are no issues with the old memory adaptors. They have always performed faithfully. The main point of the new adaptor is to fit all the model years of the legacies.
ran fine in "stock" while I moved it behind the shop where it was out of the way. Put 2v7 back in when I got fresh cleaned/matched purple tops... throws MAF code and dies Tested wires, got NEW maf... no change not sure what happened
-Bill
that is true,
HEY MIKE! what do ya think? is there anyway for me to test this? I've got access to a MACmeter that does pretty much everything, even olliscopic.... just don't know what to look for what voltages should I be seeing anyway? I was guessing they were right as they didn't surprise me.
I would just re-examine your wiring. It's seems almost definite that's where you went wrong.
Is it possible that I've toasted something in the ECU?
did you reprint the wiring directions or are you just assuming you are remember the wiring correctly? I'd be very suprised if it was't the wiring.
I'll double check the colors next time i'm over to the car... and the "butt connectors" tip is a good one anyone who is reading.
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? Last edited by Speedklix; 11-02-2007 at 05:51 PM. |
You don't have two oval injector connectors I could swipe, do ya?
GOOD stock parts and known good z32 maf for sale...
okay, so its happy again.... I back probed it, checked resistance Everywhere!, and whispered sweet little things to it... and finally found that a very small section of wire was split and "grey" about halfway down the loom. it was the return, so that is why I couldn't figure it out ...
now lets see how long it is until I find time to go move it out from behind the place Nick, I just have to figure out what box I put em in, I haven't had time to unpack anything since moving in, cept for the kitchen and bedroom. There was someone else that needed two of them I think, or was that you? How many? If you still need em anyway. EDIT...Actually those are bosch and oem connectors I have left anyway, sorry.
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? Last edited by Speedklix; 11-08-2007 at 08:59 AM. |
