Old 10-13-2007, 09:21 PM
crazyhorse's Avatar
242,000 mi on oem trans
New Headlight Polish Technique
I polished my headlights yesterday. I use a different technique than most. Being a scale modeler, I'm used to making glass smooth paint from a hazy rattlecan job. This method can be fairly quick to time consuming depending on the condition of the lenses.
Before
After
Here's my preferred method.
You need a polishing kit from a local hobby shop or www.micro-mark.com Item #80939. This kit will do as many sets of lights as you can handle, until you lose a sheet.
A bottle of your favorite wax.
Start with the 2400 grit. It helps if you let water run over the headlights. Scuff the WHOLE light. Make sure that the tone is even all over.
If the lights are EXTREMELY bad/rough, you can start with 1500 grit dry, then use 2000 grit before starting with the polishing kit.
Work your way through the grits one at a time, DO NOT skip a grit. Once you finish with the last grit, dry the lenses thouroughly, then wax with your favorite car wax.
Hope this helps someone.
"42"
Current Stable By Age:
Old 10-13-2007, 11:01 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Is that look a lot better in person?
Maybe you should take some better pictures.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 10-13-2007, 11:11 PM
nextse7en's Avatar
Graphic Artist
I've always stuck with 600 grit wet sand, 2000 grit wet sand, rubbing compound, polishing compound, then wax...
makes em look like they just came from the factory..
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 10-13-2007, 11:17 PM
nexus_7 nexus_7 is offline
My way:
PlastX buff, invisible glass clean (5-6 times per lens)
6 coats of the new turtle wax Ice paste polish. Takes a little time but they now look clean as new. Probably about 30 minutes per lens.
Greg
Old 10-14-2007, 05:36 AM
Manarius's Avatar
Manarius Manarius is offline
I just wet sanded mine with #0000 steel wool. Worked pretty well, but I think I need some more wax to get all the scuffing out....
-Jason
-Obi Wan Kenobi
Old 10-14-2007, 05:51 AM
PlastX is gr8
Old 10-14-2007, 08:59 AM
Manarius's Avatar
Originally Posted by SilverSpear View Post
PlastX is gr8
I use that after I did the wet sand with the #0000 steel wool.
-Jason
-Obi Wan Kenobi
Old 10-15-2007, 07:48 AM
Octanerush Octanerush is offline
another quick solution to polishing/waxing is after doing all the sanding. clear coat the headlamps. they look even better than polishing/waxing. the clearcoat covers up all the little scratch marks in a fraction of the time and lasts longer than the wax
[M]i[K]E[¥]
Old 10-15-2007, 08:03 AM
[M]i[K]E[¥]
This is the best solution... but you should keep the headlights at a 600 sandpaper level before coating them... or else the latter will start peeling off...
Old 10-15-2007, 08:14 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
The question that stands... Do we have one method that lasts longer than the others?
Old 10-15-2007, 09:20 AM
Yeah, go with smallcar's kit
Old 10-15-2007, 09:47 AM
Evil One Evil One is offline
Pinto Boosting Freak
Send a message via AIM to Evil One Send a message via MSN to Evil One Send a message via Yahoo to Evil One
I have 1000 grit, 2000 grit, turtlewax rubbing compound, turtlewax polishing compound, and plastX.
I plan on doing mine today.
Jim
1992 Dark Teal LS-L with 4.44 swap. NC Plate "EVIL I" *Dont Fear the GEAR*
1977 Ford Pinto baby blue with 79,000 miles
Old 10-15-2007, 10:40 AM
Manarius's Avatar
I heard that they have bad beam patterns though - is this really the case?
-Jason
-Obi Wan Kenobi
Old 10-15-2007, 11:28 AM
And here are mine. They were BAD yellow. The bulbs lit up the lens instead of shining thru.
Now... not too bad if I do say so myself.
Jim
Old 10-15-2007, 11:32 AM
It's Just Eric's Avatar
Missing in action
the headlight vut off is way more pronounced, yeah. My biggest issue with the small car kit is it looks goofy unless you do their corners (which look like junk to me) and put in a 97 grill. Even then, as soon as you pop the hood, the small car kit's poor fit and finisn is pretty obvious
As for the headlights...600 is pretty course, but if your lenses are REALLY pitted, I suppose you could start there. my personal opinion, start with 1,000, go to 1500, 2000,(Or, if they arent that bad, start here) then move on to polishing compound(s) and then plast-x
R.I.P Cool Signature.
