Old 10-09-2007, 06:49 AM
nutshell's Avatar
nutshell nutshell is offline
Send a message via AIM to nutshell Send a message via MSN to nutshell Send a message via Yahoo to nutshell Send a message via Skype™ to nutshell
Thumbs up Finally - sorted out the tyre wear
You may remember that my last posts (a while back now) were about the unexplained tyre wear on my '91 4WS and the troubles we had identifying the problem.
FINALLY I can report - problem solved.
It seems the old girl had suffered a knock to the right front corner in the past that resulted in a bent steering linkage (the Ackerman arm) that meant the toe-in differed markedly depending on which way the vehicle was steering. The result was severe scrubbing of the inside edge of the right front tyre and this was enough to destroy said rubber over a distance of about 25K km.
The bent bit was eventually isolated by the suspension guys at Pedders Suspension (now called Magwarehouse) in Gt North Road, just off the top of Mt Eden Road.
It took us two replacement hubs before we got a good one - many thanks to SVX wrecker supremo Peter out in Waitakere.
In celebration I've put a set of Dunlop Direzza DZ101's on the front and plan to replace the two near new SAVA on the back with the same in the near future.
Anyone want them?
The ride, tracking and directional stability have improved out of sight; she now goes around corners as the designers intended. Flat!
Happy days.
Ian
"The faster I go...the older I get"
Old 10-09-2007, 07:29 AM
It is very worthwhile when members report back regarding obscure problems which are fixed. In this instance it would appear that alignment carried out in the straight ahead position had obtusely corrected a fault, but in fact had only concealed the fault.
Better that this item had been included in the general technical section. Please do a write up and transfer same.
Takes a no 8 wire conversant Kiwi, to sort out real problems.
Old 11-08-2007, 05:38 AM
nutshell's Avatar
Thanks Trev - not really my doing. Just bloody mindedness on my part. It was the guys who did the work who identified the problem.
Apparently although the front hub assembly looks as solid as a rock - a huge casting - it is actually quite fragile. A good whack is enuff to put it out - so they say.
Yeah, I will get around to putting in more details in the tech section, but for now....
Ian
