Old 10-01-2007, 05:49 PM
cruisen_15's Avatar
Exclamation broken sensor...
ok there is a 2 wire sensor directly under the black box with a yellow cap saying power steering, the sensor is connected to a rail, one of the wires has come out of the sensor and if i touch the wire to a grounded area such as the intake manifold it raises my rpms and makes a hissing noise from the black box above it, anyone know what this sensor is??
Old 10-01-2007, 06:02 PM
cruisen_15's Avatar
i have looked further and it may be a coolant temp sensor, this sensor hasnt sent a CEL, could this sensor also cause some other problems for idling and ect?
Old 10-01-2007, 06:11 PM
The coolant temp sensor is at the opposite corner of the engine.
From the vague description it sounds like the sensor for the power steering system. I just took a quick look in my basement, is it a green/white and black/white wire.
Old 10-01-2007, 06:13 PM
cruisen_15's Avatar
yes, your correct, it does look just like the coolant temp sensor though
Old 10-01-2007, 06:49 PM
cruisen_15's Avatar
anyone know if i can remove this sensor?? is it under pressure?
Old 10-01-2007, 06:58 PM
If you remove it, some fluid will drain out. Just lay a rag under there to catch it.
If you want to minimize the leakage, use a turkey baster to empty the reservoir first.
Old 10-01-2007, 07:02 PM
cruisen_15's Avatar
i read that this switch also controls my idle so my car doesnt stall, and there isnt a trouble code for this sensor.... hmmm it has been idling around 120 rpm.....
Old 10-01-2007, 10:00 PM
cruisen_15's Avatar
fixed the sensor and saw no change, if anything it seemed a little easier to turn......
Old 10-01-2007, 10:17 PM
Manarius's Avatar
Manarius Manarius is offline
Idling is usually controlled by the IAC (Idle-Air Control) valve. A dirty one can cause bad idling.
-Jason
-Obi Wan Kenobi
Old 10-01-2007, 10:33 PM
cruisen_15's Avatar
i cleaned that with throttle cleaner, when the engine is hot the tub that goes into the middle right hand side of the black airbox connected to the TB's has a vacum to it, i can barly blow any air into it, and i pulled the tube connected to my tb's it killed the engine cuzz it sounds like it has extreme vacum...
