Old 09-25-2007, 02:10 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Unhappy Tranny problems
I have had a scary thing happen the last couple days. the other day I was going down the highway and was going about 60 then i punched it to pass a long line of cars and the motor just reved. It doesn't do that if i press it slowly only when its punch to the floor between 60-65mph? If anyone knows what might be wrong leave me something ASAP!!! (I think the trannys might be going bad from 3rd and 4th gears
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-25-2007, 02:49 PM
redsvx's Avatar
redsvx redsvx is offline
Alcyone ... the brightest star
Sounds like some of the clutches are slipping
92 SVX LS Pearl
94 SVX LSi Barcelona Red
82 Brat 4WD
Bob
Old 09-29-2007, 10:32 AM
Talking
I thiink i solve the tranny problem. the only thing i could think of besides a bad tranny was when the throttle is pressed all the way done at 60mph it increases the fuel intake for a sec or 2 so i replaced the fuel filter last night and it stopped reving at 60. i will kepp an eye on it but i hope it's fixed
Seth
Past subies:
Other toys:
Old 09-29-2007, 11:04 AM
redsvx's Avatar
Now that's a quick and easy fix
Hope it works!
92 SVX LS Pearl
82 Brat 4WD
Bob
Old 09-29-2007, 06:11 PM
Angry
im getting pissed the car still reved but this time at 80 mph instead of 60 after i changed the fuel filter a little inprovment but i think im gonna take it down the road to get looked at front to back so i dont rev the thing and blow it up
Seth
Past subies:
Other toys:
Old 09-30-2007, 07:09 AM
immortal_suby's Avatar
Thread Killah
sounds like you might just need a brake band adjustment.
read through this and see what you think http://www.subaru-svx.net/forum/show...ght=brake+band
Locker Link
2015 BRZ Limited 6MT
Old 09-30-2007, 09:43 AM
thanks for all the replys. So it is narrowed down to a brake band adjustment or a high clutch is shot
Seth
Past subies:
Other toys:
Old 09-30-2007, 12:05 PM
longassname's Avatar
Just some dude.
That is pretty much correct. Mostly likely both your high clutch and brake band are shot. Good news is that's the typical failure on these transmission when they are worn out so it should be a straight rebuild with no need for hard parts. I'm sure your brake drum is scored but they can usually be resurfaced.
