what was this and how
and how important is it to my car running right. i dropped the steering column, and this fell out.
also on a side note, dropping the column was a waste of time all it succeded in was crushing my nuts when i undid the last nut, and it didn't move, or provide any additional access to the bolt i couldn't get out and i had to bolt it back in to get the bolt out, however removing the seat made this much easier. so win lose oh well needed to get that out. any way this is the pic of what i broke
1991 xt6 eg33? 1993 gc track car |
Jeff, I dunno what that relay is, but watch the "jewels" when you pull that last bolt on the column. Especially if the wheel is off.
I caught a Taurus column the exact same way... sang soprano for a couple hours! (who knew you had to remove the WHOLE dasboard to do a heater core?)
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
It was a '95 wagon, it finally succumbed to the infamous tranny issues @ 198k mi
[/hijack]
as funny as that post was...
I have no idea what you have there looks like it says "dude" on the side? and the benefit of removing the column is to make it easier to fab up/install the pedals... if you don't you'll end up doin it like I did, ready: -remove bolt holding the pedal cage aligned -twist cage 90 - 180 degrees -push gas pedal end over the column -move the wires -no the other wires -rotate cage back to aligned position -move the wire again -okay push booster in no that the cage is clear -pull booster through -attack two bolts to booster -ohh wait the cage can't tighten down with the studs in the way -remove alignment bolt again swing it down -tighten the booster -okay, move the wire again -swing the pedal cage back up guesstimate the position of the hole to be drilled, mark it. -unbolt the booster -push the booster out a bit -get out and pull the booster out a bit more -get back in the car -slide the booster out as you pull the pedal cage off the rest of the studs -twist the cage -MOVE THE WIRES AGAIN?!?!? -rotate the cage around the column -twist the cage again and pull the cage out the rest of the way -$@#T?!? NOW WHAGT THE EFF IS IT CAUGHT ON>!>!>> -drill the hole for the stud -repair broken window ...pretty much repeat that to get it in and then a bunch more times for cutting and welding with the column out of the way you pretty much could just put it up where it needs to be and go to town
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? Last edited by Speedklix; 09-22-2007 at 09:31 PM. |
come to think of it, I had to do some cutting before I even got to that point...
+3 more times
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
i havent had to cut anything yet, i'm just hoping that circut board isn't that important
If it says "Guide" on it, I'd assume a headlight relay of some sort?
i'm drawing a blank on what the main relay looks like... but if there are no wires in the area it came from, you shoulod be in good shape. may have just been from an old alram system.
Does you car have an alarm system, I had to remove mine until after the swap ....btw don't cut the wire that is spliced in to the starter, it DOES belong there I thought it went to the auto starter
lol, my alarm is already disabled, i'm just gonna have to try to start the car and find out, hopefully nothing big
We broke that same thing when we were installing the 5-speed in the racer. I'm not sure what it is, but I grabbed another out of the junkyard. I looked it up in the FSM, and I seem to recall that it was needed, and we have no headlights or other heavy weight extras....
that is so funny heheh
Jerry 2005 Baja Turbo 2008 Ford Crown Victoria Police Interceptor jnj7707@yahoo.com |
its the blinker relay... not too important until you need to use blinkers
Tom |
