Old 09-07-2007, 01:26 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Need help asap installing clear lenses
Okay so I got these in the mail:
I took out my headlights, heated them up, split them apart, but now I'm stuck. These lenses fit over top the front part of the housings and I have no idea how to split the actual lense off the black part. I think the whole piece is the same thing, just most of it painted black..? Do I have to use a hacksaw and just kinda eyeball it?
Brian
Old 09-07-2007, 01:31 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
i thought you were supposed to dremel tool the original lens off ( assuming you got them from small car) ~ i know small car has instructions off the web site. you can check that out
Old 09-07-2007, 01:36 PM
Ricochet's Avatar
I brought some ham.
crap. got a link?
Brian
Old 09-07-2007, 01:39 PM
Google -> "Small Car"
Old 09-07-2007, 01:40 PM
http://www.smallcar.com/svx/hlkinstructions.htm
Old 09-07-2007, 01:44 PM
Ricochet's Avatar
I brought some ham.
wow 12-16 hours cure time? I'm actually in a hurry to get this done so I can go out tonight!
Brian
Old 09-07-2007, 01:59 PM
It's Just Eric's Avatar
Missing in action
ya...smallcar's lenses are kinda chintsy. you'll have to cut the ever loving snot out of the sock peice to do it
R.I.P Cool Signature.
Old 09-07-2007, 02:02 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Take your time. It will really look good if done right, but you will see glue marks if you rush it.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 09-07-2007, 02:47 PM
Ricochet's Avatar
I brought some ham.
oh boy.. all I had to work with was an A/C dremel thing meant for rescuing people from crushed cars. It only had speeds of off or ludacris. My housings are all chewed up, this sucks.
Brian
Old 09-07-2007, 04:25 PM
Nevin's Avatar
Nevin Nevin is offline
In that case, whose lenses do you recommend?? I myself was looking at nabbing a set of smallcar lenses, but knowing this just may make me change my tune.
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 09-07-2007, 05:08 PM
Ricochet's Avatar
I brought some ham.
It would be 100x easier if you use a sandwheel dremel with adjustable speeds. No heating up of the silicone required - just take out the entire housing, saw off the old lense, and glue on the new one. Viola.
Brian
Old 09-07-2007, 09:46 PM
Missing in action
Yeah..I dunno man..They are okay IF and only if you can manage to install them good...but there will always be that ugly seam staring at you when you pop the hood. Dont get me wrong, they LOOK GREAT, but the way they go on is kinda half fast
Old 09-08-2007, 02:19 PM
Nevin's Avatar
... Dont get me wrong, they LOOK GREAT, but the way they go on is kinda half fast
So what would you suggest would look better?
Jesus is the remedy
Old 09-08-2007, 02:39 PM
Ricochet's Avatar
I brought some ham.
nothing. It's either these or stock foggy lenses.
Brian
Old 09-08-2007, 04:57 PM
Speedklix's Avatar
Locker Link Solution
never even seen em in person, so i could be soo off on this ...but I figured I could just putty over the seam, to make it look "OEM" more than anything else really.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
