Old 08-30-2007, 12:21 AM
92svx95 92svx95 is offline
Originally Posted by Hocrest
Personally, Ive had it cause problems not with hot or cold starts, but with warm starts. When I try to start it after sitting for 15-30 minutes. But others have had it cause hot start issues.
hmmmm.. would u consider a hot/cold startup when u have to pump the gas really really fast and quick while u crank the ignition key over until it starts? usually cold/ hot startups.. once it warms up a bit it runs fine...
Old 08-31-2007, 11:58 AM
Michael Blue's Avatar
Michael Blue Michael Blue is offline
Sold. :'-(
Huh...Good info.
My alternator was shot, but is replaced, and the car is still stalling when warm.
No starting problems at all though...
Anyone have pics or a DIY on the coolant temp sensor replacement?
I'm going to have to dig more into this.
Thanks!
'92 Pearl White LS-L Touring SOLD
4.44 Swap, trans cooler, trans filter, trans temp gauge
Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines
Raxles front axles
Old 08-31-2007, 02:25 PM
dcarrb dcarrb is offline
Originally Posted by 92svx95
would these sensors (if bad) cause the svx not to startup?
I had cold start trouble, and it only seemed to happen at around 32 degrees. The engine would just grind away and not even try to fire, but would start readily with the accelerator held to the floor. Replacing the coolant temp sensor completely solved this problem.
Get the sensor from any auto parts house for <$20. You'll need a 22mm deep-well socket (this size also fits the wheel lug nuts). Five minute procedure. I had more trouble getting the wires loose than removing the sensor.
Note that my car had no drivability/stalling problems.
dcb
Old 08-31-2007, 08:12 PM
dcb
wheel lugs are 19mm
tom
Old 09-01-2007, 07:34 AM
Sold. :'-(
OK, going to buy a deep-well socket for these today, need a definitive answer. Thanks!
Raxles front axles
Old 09-04-2007, 06:59 AM
Originally Posted by TomsSVX View Post
wheel lugs are 19mm
tom
Shoot, then that's what you need for the coolant temp sensor, 19mm. My bad; sorry about that.
dcb
Old 09-04-2007, 09:47 AM
If you still have the original stock tool kit, there is a nice deep 19mm socket in there
Old 09-04-2007, 11:17 AM
Sold. :'-(
LOL! OMG, I'll have to look.
Does anyone have a pic, diagram or anything of where the sensors are located and how to get at them? Also, part numbers for ordering would be handy.
THANKS!
Raxles front axles
Old 09-06-2007, 11:19 PM
did u ever fix yur problem?
Old 09-07-2007, 04:31 PM
Sold. :'-(
I haven't had a chance to look further into it yet...Been working 12hr shifts on 3rds, lol!
I'm off now until Monday, so I'll try to get to it this weekend.
If anyone has a pic or diagram of where these are, part numbers for them, or a DIY/FAQ on the repair, I'd be very indebted.
Thanks!
Raxles front axles
Old 09-08-2007, 02:21 PM
rbalach rbalach is offline
I've attached 3 pics to help you find the sensor. The brass colored sensor in the third pic is the one i changed out to fix my hot stalling issues.
Regarding the part numbers you can search through the website below (click on the blue SVX link at the top of the page , you will have to create an account and login)
http://www.subaruparts.com/
Old 09-09-2007, 08:27 AM
Sold. :'-(
THANK YOU!!
I'll get on ordering those and I'll let you all know as soon as they're in.
Thanks!
Raxles front axles
Old 09-10-2007, 02:52 PM
Sold. :'-(
O'Reilly can't find a listing for the one that goes to the ECU, and the dealer can't even find a listing for the car.
I've got them digging through old books and they're supposed to call me back.
Part numbers would be a HUGE help.
Thanks!
Raxles front axles
Old 09-10-2007, 03:47 PM
Sold. :'-(
OK, here we go....
1992 Subaru SVX LS-L Touring AWD -- Coolant Temperature Sensors
Dealer
Pt # 21203 AA 030 (to dash cluster)
$ 42.38
Pt # 22630 AA 041 (to ECU)
$ 27.77
O’Reilly Auto Parts
Pt # BWDWT522 (to dash cluster)
$ 12.49 Borg/Warner (lifetime warranty)
Pt # WT5056 (to ECU)
$ 22.99 Borg/Warner (lifetime warranty)
I'll save a bit over that because I ordered them through a collision center, but there you go.
I'll get them tomorrow and put them in this weekend.
Thanks!
Raxles front axles
Old 09-10-2007, 03:56 PM
Thanks!
Sensor for ECU (two wire) 22630AA041 discounted $21.16
Sensor for gauge (one wire) 21203AA030 discounted $32.30
They show to be widely available at most dealers.
You beat me to it
