Old 08-16-2007, 01:49 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
sunroof problems
shortly after getting my svx out of storage my sunroof will move back and forth on the track but it wont go all the way down! does any body know what could be causing this and are there other fixes then buying a new sunroof?
- John
Old 08-16-2007, 02:00 PM
94SubieSVX's Avatar
OOC for a while
stand outside and push the close button then push down on the sunroof from outside
bLAh
Old 08-16-2007, 02:01 PM
Suby Fan's Avatar
some how i see that braking even more stuff
- John
Old 08-16-2007, 02:19 PM
94SubieSVX's Avatar
OOC for a while
It probably would, I was kidding about that though.
bLAh
Old 08-16-2007, 02:55 PM
Blue94 Blue94 is offline
Mine did the same thing. I spent an hour or two cleaning the guides and re-lubing. Didn't help. Finally I watched the sunroof from the outside as I closed it and noticed a tab that was protruding from the guide that was blocking the roof from progressing. I took a flat head screwdriver and pushed the tab in and walla, the sunroof closed.
As for a fix I can't help you there, I just gave up on the fact that I had a sunroof and never correctly fixed it.
Blue
Old 08-16-2007, 05:23 PM
Check this thread with photos
http://www.subaru-svx.net/forum/show...=sunroof+guide
I had the same problem and svxcuseme came to my rescue. No problems since.
Old 08-16-2007, 07:41 PM
redlightningsvx's Avatar
Collision Refinishing Tech
mine will not go up when i press the button so i push up and press the button and it works then any advice? Because im thinking its the motor
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-30-2007, 09:49 AM
Suby Fan's Avatar
ok thank you for the replies i found a little piece of plastic in the track and fished it out and now it works again as for you red lightning you need to clean your track out and re grease it i have the same problem and its just due to gunk build up in the sunroof tracks
- John
