#31
Well if everyone waits till later the price is going to be higher.
#32
There are two sets in production which should be done the end of february. One of them is mine. The other is available to the first purchaser. Since people did not get together to get a larger batch made to start with the price will be the same as the forced induction pistons. In fact you can just order them using the link for the forced induction pistons and include a note that you want the na pistons not the forced induction pistons. http://www.ecutune.com/svx_pistons.htm
#33
oh, and these are for bores 2 steps bigger rather than one. Stock pistons are for 96.9mmbore , our forced induction pistons are for 97mm bore, the new forged pistons for naturally aspirated engines are for 97.15mm bore.
#34
I know there is somebody who is looking to do a full na build and wanted to order pistons like a month ago and then didn't when I suggested he might want to wait for the smaller camshafts I'm about to have for na cars that don't want to run high rpms and go with the 97.15mm bore I was ordering.....I don't know who that is though. There is only one set of pistons besides the set I'm keeping for myself. I expect them to be done before the month is over and will sell them to the first to pay so if you want them.....be that person.
#35
Re: ECUtune forged pistons for NA SVXii
The engine I built with these pistons (which was a huge success ) is now for sale:
http://www.subaru-svx.net/forum/showthread.php?t=63349 http://www.ebay.com/itm/231495015657 |
#36
The ebay auction ends in 2 days and it looks like it's going to get sniped in the last few. Since I'm breaking open a complete Subaru gasket and seal set to swap out the cams I decided it only makes sense to do a complete reseal on the engine so whoever buys it knows they will be good for a long time. That's what I always do when I'm installing an engine in one of my cars I figure anyone else would appreciate the same.
I went ahead and ordered a new head bolt set for the job. I'm going to go get the wood and get started on the crate now. |
#37
I'm mainly posting this because I'm tired of seeing the #1 post in the mod forums being about fog light bulbs.
The engine with the 9.3 compression pistons is still for sale. I've gotten side tracked rebuilding the 4l30e out of my passport but I'll have it out of the way soon enough. I had the crate for this engine essentially done when I left off. I think I'll have this engine freshened up and in the crate by the end of the week. |
#38
Me too
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
#39
I tore the 9.3 compression engine back down to the short block yesterday to get it ready to reseal and sell freshened up.
There was no metal in the pan or contamination in the oil indicating wear. Everything looked good. I cleaned the mating surfaces all old sealant, prepped them with prep-solv and re-installed the pan with ultra-grey. http://www.subiechips.com/posts/9.3/20150320_181522.jpg The pistons and cylinders look great too. I cleaned off what little carbon build up was on the tops with some wd40 and wiped down the cylinder liners. I also chased the threads of all the head bolt holes. It's always a good idea to chase the threads so they are perfectly clean. That way your torque measurements when torquing the cylinder heads down accurately reflect clamping pressure and instead of resistance to being turned. http://www.subiechips.com/posts/9.3/20150320_185631.jpg I apologize in advance for the pictures not being of the quality I used to post. They were taken with my cell phone--not a nikon dslr. Does anyone know how to specify the size of an image if I use IMG tags instead of URL tags?
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 03-21-2015 at 06:44 AM. |
#40
I got the heads for this engine back from the machine shop today. I got a valve job and the deck done while they were off.
I cleaned the RH deck with prep-solve. Installed the RH head gasket Took a picture of the RH cylinder head before cleaning the mating surface with prep-solve Put bolt grease on the threads and heads of the new head bolts When torquing the head bolts I like to mark them after I torque them to 51 ft-lbs/before I start the loosening them and re-tightening them by angle procedure. This makes it easy to keep track of where they are and make sure everything is going right. After I've loosened them and re-torqued them to 20 ft-lbs you can see the long bolts are about 120 degrees shy of where they were at before and the short bolts are about 90 degrees shy of where they were at when torqued to 51 ft-lbs. At this point I mark the block 180 degrees off from the markings on the bolts. This gives me a don't go past reference point for each bolt. At the end of the torquing procedure you can see I end up with all the bolts about the same angle past where they were when first torqued to 51 ft lbs. repeat for the LH cylinder head. http://www.subiechips.com/posts/9.3/...d/DSC_0555.JPG http://www.subiechips.com/posts/9.3/...d/DSC_0566.JPG http://www.subiechips.com/posts/9.3/...d/DSC_0571.JPG http://www.subiechips.com/posts/9.3/...d/DSC_0573.JPG http://www.subiechips.com/posts/9.3/...d/DSC_0581.JPG and now the heads are on.
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 03-26-2015 at 08:51 AM. Reason: url -> img tags |
#41
I cleaned the lash adjusters for this engine today. I'll give you a little how to here. This is good knowledge for the community. This should probably be done anytime an eg33 is taken apart. This is the fix for noisy lash adjusters. The oil inside your lash adjusters is as old as your car is. You absolutely must do it anytime you've made modifications to the valves or camshafts that might reduce the clearance between the two.
The hydraulic lash adjusters are composed of 4 parts. The following link is to a picture of a lash adjuster I have taken apart and cleaned. I'm going to call the part that sits on the end of the valve stem "the pedestal." That's the part you see sticking out of the bottom of the lash adjuster if you are looking at an assembled lash adjuster. It's the right most part in my picture. To it's left you see a spring which fits inside the pedestal. To the left of the spring you see the check valve which also slides inside the pedestal..except the spring wants to push it most of the way out when the lash adjuster is dissassembled. Left most is the main body of the lash adjuster which I've heard others call "a bucket" so I will do the same. There is a small hole in the side of the bucket which lets oil into the interior of the bucket. The check valve lets oil from the interior of the bucket through into the space inside the pedestal where the spring is. It's a one way gate--if there is open space inside oil will go in but it can't come back out. So the way this works is the spring gently pushes the pedestal down to take up any lash between the camshaft and the valve stem then oil fills the space making it uncompress-able. The internal parts just push into the bottom of the lash adjuster. They also just pull out. There's a little lip on the bottom of the pedestal which you can grab with a regular pair of pliers. Holding the bucket in one hand and grabbing the lip on the pedestal with a pair of pliers with the other hand you can pull the internals straight out of the lash adjuster with ease. Shake the oil out of the bucket, wash everything out with a light oil, put the spring in the pedestal, put the check valve in the pedestal, push everything back into the bucket. Here are all 24 lash adjusters for this engine after I disassembled, cleaned, and reassembled each one.
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 03-26-2015 at 08:53 AM. |
#42
Picking up where I left off...I had cleaned all the lash adjusters and tried to illustrate how to do this to fix your clickity clackety eg33's. The next step is to bleed/prime your lash adjusters.
Pour yourself a container of penzoil platinum 10w30 and submerge one of your lash adjusters in it with the oil hole on the side pointing straight upwards. Squeeze the pedestal. A string of air bubbles will come out when you squeeze it. When you release it clean oil is sucked in to replace the air you just squeezed out. It takes about 65 pumps for each lash adjuster to complete the process. Your thumb may get tired somewhere along the way but you also get a warm fuzzy feeling as you can feel each lash adjuster operating smoothly. I like to go straight from priming the lash adjuster to dropping it in the cylinder head. When you are finished you are 100% certain all your lash adjusters are smooth and quiet and none of them will be holding any valves open costing your compression. |
#43
So after you've cleaned and primed your lash adjusters they are smooth and soft. This makes it very easy to install the camshafts. On the left had cylinder head the camshafts install with the notches facing downwards. With clean lash adjusters the camshafts drop right.
When you took the camshafts out you should have put a bolt in the intake camshaft gears to hold the scissor gear in its preloaded position. After you install the exhaust camshaft with the notch in the front straight down (on the lh side) you install the intake camshaft with its notch in the front also straight down (on the lh side) and the tooth with the single dot in between the two dots on the exhaust camshaft gear. After you install the #'d cam caps (unless you are working on a later model non lsi engine where subaru decided you didn't deserve #'d cam caps) it's time to remove the bolt holding the scissors gear back before installing the front cam cap You always have to use new gaskets on the valve covers. Even if your gaskets are almost new and seem perfect..you still have to use new gaskets. That includes the bolt gaskets. Because the bolts bottom out against their shanks they install to the exact same height each time--no amount of torque will make them pull tight on a gasket that isn't brand new. The big problem with this is that someone at Subaru made a mistake back in 1990 that has never been corrected. Their computer says the SVX take 16 bolt washers. It takes 20. So you'll invest close to $500 in a gasket set to make sure you won't get caught without a gasket you need...then you get caught without gaskets you need. If you are ordering your gaskets individually order 20 bolt gaskets. If you are using an overhaul set order yourself an another 4 bolt gaskets. |
#44
On the right hand side the notches on the front of the camshafts go straight up vs straight down on the lh side.
#45
Then it's time to put new o-rings on the dipstick and the top of the block for the water crossover pipe and install them. Then a new timing belt tensioner and close to new idlers. Then the close to new engine harness. And that brings us up to date. I'm waiting on new lower intake manifold gaskets, a new right hand rear timing cover, and a new set of spark plugs before I can button this engine the rest of the way up.
