Old 07-21-2007, 10:10 AM
94SubieSVX's Avatar
OOC for a while
crank sprocket
im trying to take it off but its being a pita. anybody know of a easy way to get it off?
bLAh
Old 07-25-2007, 01:20 AM
tap the two holes with a 10x1.25 metric tap. The use a straight puller to pull it off... DON'T pry it off... I made that mistake
Old 07-25-2007, 09:08 AM
94SubieSVX's Avatar
OOC for a while
I ended up tapping it with an 8x1.25 metric to get it off. It took about 2 hours since i didn't have a straight puller. I took a flat piece of steel and cut two holes in it and used two 8mm bolts put through the steel to pull it off.
bLAh
