Anyone interested in tubular headers?
I have received a few PM's about making some after posting pictures of the headers I made for my EG33 powered 911. Pictures can be seen here...
http://www.subaru-svx.net/forum/showthread.php?t=39188 They use 1 5/8 primaries, into a 2 inch slip collector flared out to 2 1/2 and a v-band flange. These would be prefect for high performance NA engines, and supercharged engines. There would be no previsions for emissions controls. Now for the important part. PRICE. Custom, hand fabricated parts take a lot of time to build properly. The price would probably be about $1000 with ceramic coating. I would need a minimum of 10 orders at that price. There is one catch though. I would need a local AZ person to "donate" their car so I could make the first set (I don't currently own an SVX). There might even be a discount given to said volunteer Anyway, respond here if this is something you think you might be interested in so I can get an idea if this a project I should pursue. Please hold your comments if you feel like the price is too high. I work in the automotive performance industry so I know a thing or two about how long things take, and what things cost. Trust me, that price is more than fair for such a limited quantity item. Last edited by kcpaz; 07-14-2007 at 10:24 AM. |
Sounds like a fair price to me. I can't dedicate myself right now, But count me as interested.
Nice price, especially since those slip collectors probably run around $300 for a pair. Who'd you end up getting them from? Did you use 304 SS?
-Bill
that's a secret I have a lot of secret sources that I've aquired from years of experience and research. Using stainless would greatly increase costs. Stainless is harder to cut, more complicated to weld (you have to back-gas the bead) and obviously the material is more expensive.
-Bill
Tom |
aluminized is not a good choice. The aluminized coating has to be grinded off for welding (just like galvanized coating) if you want to do it right. Even if you do use aluminized tubes, you will have to get it removed (acid stiripped?) before ceramic coating. If you just rely on the aluminized finish for corrosion resistance, it will quickly fail...especially on headers. Plus, the weld areas won't have any corrosion protection. It's either stainless or ceramic coated mild steel if you want to do it right.
As far as using stainless... I would only spend the extra money if I was making a header for turbo applications. Other than that, I think it is a waste of money...especially for a street car. On a race car where EGT's are higher for extended periods of time I can see it, but there is no horsepower gain in a street car. |
they look real nice and i would like some BUT i cant afford any thing like that ay
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired 1989 Vortex 6 Maroon 1983 RX Silver Grey 1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration |
I understand that but aluminized is also much easier to find... I guess you could find mild steel as well but I didn't bother to look... Anyway, I hope u can get these started... I know for a fact just how hard they are to make on your own and svxfiles does too... Good luck and I hope you can get the order filled... U know I had people complaining that 1500 was way too much for a set not too long ago... now 1000 its just the right price with 10 orders Good luck and thanks for opening another door for the aftermarket of the SVX
Tom |
I'd be interested in one, but only after some dyno tests that show the results. Sorry dude.
Wow, they look awesome, Im just wondering if they will really increase the flow, since the stock manifolds seem pretty unobstructed.
Im in Phoenix AZ, you can use my car.... I guess I can get a better price right?? |
I doubt there will be enough intrest in these to start making them. It was a nice thought though
his headers are going to be very similar to mine. They flow so much better, that coupled with a bigger exhaust my s/c car dropped over a half second in the 1/4 mile. This gain was due to the restrictive design of the stock manifold and I needed something more. They are worth it... but only if you are going to be doing work that requires more flow in the future
Tom |
Im deffinetly going to supercharge or turbo my car, but first I have to finish my 280Z project. But I deffinetly want to put money on the SVX. and I deffinetly would like those headers, even if they dont give me that much power, there is no doubt they will flow way better than the stock ones.
Headers FTW!! |
Thread Tools | |
Display Modes | |
