Old 07-11-2007, 01:56 AM
TheWheelMan TheWheelMan is offline
best subie tranny for an svx swap
im looking for the years of the cars subaru produced with the 4eat transmissions that will fit in a svx
Old 07-11-2007, 02:09 AM
Nomake Wan's Avatar
Retired
1990-1998. If you really wanna swap, get one from 1998 I guess. It's pretty popular to use a 4.44 final ratio transmission from later model year Subies (though I'm not sure what models have what final gear).
Old 07-11-2007, 04:52 AM
Manarius's Avatar
Manarius Manarius is offline
4.44 is pretty much only found in the Outback. 4.11 is pretty good and it can be found on most non-turbo automatic Legacy's and some manual 2.5RS's.
-Jason
-Obi Wan Kenobi
Old 07-11-2007, 05:08 AM
The Legacy GT, and Legacy Outback, and Impreza RS with an automatic have4.44's (as do some Foresters I believe) the regular Legacy, and Impreza's came with ither 4.11's, or 3.90's
Any Auto tranny you install from a different Subaru WILL require a gear swap in the rear diff, as only the SVX came with the 3.54 final drive ratio
Hope this helps
Old 07-11-2007, 05:13 AM
Manarius's Avatar
Hope this helps
My mistake
I always forget which ones got the 4.44. Why can't they all just come with the same thing!?
Better listen to Huck, he's always right on these things.
-Jason
-Obi Wan Kenobi
Old 07-11-2007, 05:19 AM
cdvs cdvs is offline
Which Rear to Modify?
I've found instructions for swapping the higher ratio gears into the SVX differential and for adding the Limited Slip bits into the higher ratio differential.
Which method is better and why?
Charl
