Old 07-07-2007, 12:41 AM
kwren's Avatar
kwren kwren is offline
Please HELP!! does anyone know how to remove the Crankshaft Sprocket?
this Crankshaft Sprocket thing has to come off to replace the oil pump eral and o ring. It looks like it has 2 holes that bolt could be screwed into and that would push it off? If this is not the case, it ain't happening
Old 07-07-2007, 06:47 AM
AFBeefcake's Avatar
Subaru Swapper
I think you need to use a puller if its stuck on there.
2005 Legacy GT
My WRX's Cardomain Page
Old 07-07-2007, 09:21 AM
thread those 2 holes with a metric 8x1.25 tap. The use a flat steering wheel puller to take it off.... DON'T pry it of from behind.... that will only bend the timing sprockets and break them
Old 07-07-2007, 09:49 AM
The manual advises:-
Tap the two holes in the sprocket using a 8 mm, 1.25 mm pitch tap. Drill 10 mm holes on a 41 mm radius, in the plate on a puller. Fasten the plate to the sprocket using two M8 bolts. Use the puller centre bolt against the end of the crankshaft to remove the sprocket.
On this basis a puller could be knocked up using a plate and a large nut and bolt.
Old 07-07-2007, 09:58 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Knocked Up???
"Knocked up"?? Humm, then we will have a some little pullers around. J/K Trevor. In our colonial English knocked up means getting pregnant by accident.
Just another of those unexplainable differences in the supposed same language.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 07-07-2007, 11:09 AM
kwren's Avatar
decypher?
To decipher…my messages please visit:-
http://www.chemistry.co.nz/kiwi.htm
I went to your web site Trevor for some clarification but Knocked up wasn’t on the list!
Thanks everyone for your help!!!
I really appreciate it!
Take care everyone,
Keith
Old 07-07-2007, 01:16 PM
kwren's Avatar
Trevor?
Yours is a real interesting web site!
Old 07-07-2007, 11:50 PM
Originally Posted by kwren
decypher?
Take care everyone,
Keith
In my distant youth this was a common term meaning to put something together quickly and using what was on hand. At the same time there are knockers,( Several varieties) and those who get knocked up.
Old 07-10-2007, 06:55 PM
immortal_suby's Avatar
Thread Killah
good advice.
........and I have a main crank sprocket with busted off timing sensor teeth to prove it
Locker Link
2015 BRZ Limited 6MT
Old 07-10-2007, 08:27 PM
Originally Posted by immortal_suby
good advice.
I did it at reading because I didn't have a puller or the correct tools to pull it... Man that was a scare but Hocrest to the rescue
Old 07-12-2007, 04:14 AM
STORMINORMAN STORMINORMAN is offline
Question One question...
Is "up the duff" somehow related to a "plum duff"?
Oh, bugger all!
Cheers!
p.s Trevor: please read and comment as you feel appropriate on my post re: the two power steering systems & brakes
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
