Calling all Koni/GC users... (or anyone with Koni Yellows "smarts")
Hey guys, I know it's been a while since I've posted on here... What can I say, I work full time and go to school... My summer is sucking somewhat...
Anyway, lets kick this off since this is the "Technical Q&A" Forum... My suspension... Koni Yellow Strut inserts (set on full firm) Ebiach Springs (380lb/in F and 325lb/in R) The problem... I recently replaced my front struts because the passenger side one was leaking fluid at the adjuster "nipple" (at the top of the strut)... No biggie, Koni sent me new ones and I sent back the old ones... HOWEVER, 2 weeks after having the new ones installed I noticed that BOTH of the struts were leaking from the same place (adjuster "nipple")... This absolutly baffles me and to be honest, I am really getting sick of it... What I need to know... 1.) Is there anyone else out there that has experienced the same thing? or am I all alone with this problem? 2.) Is there something wrong with turning the Koni yellows on "full stiff" ? 3.) What EXACTLY are the recommended spring rates for those struts? 4.) Could old top hats cause failure of the struts? 5.) Anything I missed? Thanks very much in advance guys... I need to get this mess worked out quick... I have done nothing but work, go to school, pay bills and get the SVX worked on this summer... It gets to be quite a drag after a while so any help sorting this mess out would be great... Thanks
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
Had the same leakage/weepage from the strut tops since about 6mos after install. Was waiting to retire so car could be down for a bit. Guess it's time to pursue this.
1) YES, both sides front. No easy access to rear so no idea if same prob there. 2) Mine are only mid range, so I doubt that is an issue. 3) Mine are OEM. 4) Doubt it, but mine are from the original, and not updated years. 5) Yep. Any problems with rears leaking? and......thanks for asking. Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
yes mine leak too, everyone's do... Has to be something wrong with the inserts themselves. They leak w/ oem springs and g/c alike... I have 450fronts and they leak as well
Tom |
I'm wondering if they just had a defective batch or run of the struts. I'm also not entirely happy with Koni's replacement policy, requiring you to pay half retail price for the new units, to be credited by Koni "IF" they deem it a warranty-able issue after inspection. Guess I'll be going through it though.
No known issues with the rears? No fun opening it up to find out. Key Learning:................. 'it happens. Glenn
Only one of my fronts leak.
Neither of mine leak, but mine were purchased about 4 years ago.
That's it... I'm calling Koni and making sure that they know that almost all of our struts are leaking...
Alright... Here's what I got from Koni Technical...
They believe that if you run your ride height too low (mine is all the way down) and subject the suspension to hard blows (ie. pot holes, speed bumps or even cornering with sticky tires on) then you can damage the seal that is at the top of the strut... Tech recommended that I raise the ride height by about .5", send the struts I have now in for warranty replacement ( again ) and see if anything changes... Also I was instructed to drive the car everyday with the adjustment either on full soft or 1/2 way between soft and hard... Continous use at or near full stiff will cause the strut to wear out faster... All in all not a bad conversation I had... When I told him that a good portion of the other SVX owners are complaining of the same problem he said for us to check our ride height and raise it alittle... Unfortunantly after the strut starts leaking, it is pretty much toast... Mine have been leaking for about a month now, but the handeling is still about the same... After they loose enough oil though the handeling will start to go downhill... My old struts leaked for about a year before I had them replaced (and that is with about 10,000 miles and atleast 5 Autocrosses on them)... Hope this helped out!! Koni FTW!!
Thanks for the info. Guess it's time to move on this. No ride height issues here! Disappointing to have a "lifetime" product fail so soon under what I could only describe as "gentle" use.
Glenn
I am actually above normal height due to my exhaust clearances... I am a turn off full soft for driving it on the street... still leaking oh well I guess when they take a crap I will send them back
Tom |
Does this mean you have to pull out the insert cartridge and reinstall back in the stock strut housing when you get it back?
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
yeah, just pull the insert and install the new one... simple and you don't even need to take it out of the car
Tom |
Alright, I brought my rideheight up about .5" and OMG!!! It feels SOOOOO MUCH BETTER!!! I'm even thinking about bringing it up another .5" because it really doesn't look bad at all... Still alot lower than stock... Anyway, there's a tip for all of you that have the spring perches all the way down like I did
