Old 06-05-2007, 12:36 AM
StelthSvx's Avatar
StelthSvx StelthSvx is offline
outer CV boot....
I finaly pulled trigger and picked up a new 07 WRx 5MT last month. First mod some Eibachs, Evidently i was a bit rough on one of the outer cv boots(bottom of strut r grazed boot causung a tiny crack and grease leak(as evident by specks of grease on inside of rim. i decided to try and tackle this myself. Got the hub off the car.... Peeled back outer boot and whiped of old grease.......im stuck,,,,how do i dissasemble driveshaft...looking at joint its the kind with 6 ball bearings in a cage........i havent pulled the shaft from tranny trying to do it on the car..........any advice??? PS Stealership wanted $240 P&L to change boot....thanks guys
92' Claret LSL 282,000 miles 1owner(ME)
07' Pearly WRX 40k Cobb Stage II (sold)
SVX+$$$+GreaseMonkey =
Old 06-05-2007, 05:35 AM
If you clean out all the grease, you should see a snap ring in there. Remove that, then you'll be able to take it apart. Then stretch the new boot over the end, then re-grease and re-assemble.
Old 06-06-2007, 01:48 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
its not worth the hassle to try to rebuild it and you have to remove it from the car to do that.. i would recomend buying a new one at a parts store they are only 50 bucks
- John
