Old 05-16-2007, 02:19 PM
kbarrett kbarrett is offline
'92 external tranny filter
Who makes the external trans filter on '92 SVX's? Part #?
The one that bolts down in front on the passenger side?
Where can I get a replacement?
Old 05-16-2007, 02:47 PM
Nevermind ... found it via search. Subaruparts.com 92 campaign filter was what I was looking for.
Old 05-17-2007, 07:56 AM
SVX_MY_BABY's Avatar
When do these need to be replaced?
Old 05-18-2007, 02:12 PM
I suspect they get replaced when they clog and cause the AT to burn up.
Old 05-18-2007, 02:26 PM
dcarrb dcarrb is offline
Not sure there's any specified service interval. Replacement every 24,000 miles ought to do, I think, provided you also change the fluid on a regular basis.
dcb
Old 05-22-2007, 02:20 PM
PaulCa13 PaulCa13 is offline
Send a message via Yahoo to PaulCa13
External Trans. Filter
My local Subaru dealer could find no information at all on the external transmission filter. Mine, actually, is under the driver's-side fender, near the front. If you don't have any luck finding an OEM unit, you can get a generic one from NAPA for a bit under $30. They come in 3/8" and 5/16". The inlet and outlet connections are at opposite ends, so you'll likely need a couple of feet of fuel line to compensate for that.
Old 05-22-2007, 02:53 PM
The part number for external filter kit that was installed on the 92's is 31099AA370
Old 05-24-2007, 08:31 AM
gianspi gianspi is offline
Do you know the part number for the NAPA generic one? I tried the Subaru part number in the above post, but my dealer says it is discontinued.
Old 05-24-2007, 10:19 AM
From the ATF External Filter Kit TSB found HERE
"The filter is designed to be maintenance free under normal driving conditions. It will not require periodic replacement. The only time replacement is necessary is in case of a transmission failure which leads to excessive metal contamination of the fluid."
