#46
I don't see anything preventing that. An intercooled turbo setup could be used to feed the twin screw supercharger.
if I can ask though..can we possibly not generate 3 pages of high boost fantassy posting in this thread. Fantassy life can be fun but people have problems finding the real info amid so many pages of chit chat.
#48
Mike has it right... When running 93 octane I will limit my built engine to 12psi via the pulley I have... when and if I feel some sort of injection (water or alchohol) is suitable I will have a larger crank pulley made to run at tops 18psi. Tom |
#49
Far better to do what can be done to a level of excellence. It is good to see this work progressing in a realistic, considered and careful manner. My own Eaton blower has a higher tendency to heat than the Whipples, so I will be using water injection with mine, because I have to. I've my sights set on 9 lbs boost, which I hope will deliver 320+ hp in an idealised installation. I am more focused on the torque increase rather than the horsepower, both are welcome. I'm sticking with the auto, although most people going forced induction tend to want manual gearbox control. However, I am leaning stronger to changing the final drive gearing to 4.11 or maybe even 4.44. My brother has a manual Forester Turbo from Japan. Big turbo, it makes 240 hp or so. However, it always felt stronger than my 270 hp Legacy that had two sequential turbos. I put this down mostly to the lower gearing. Legacy was 4.11, Forester is 4.44. The high top ratio of the 4 EAT makes it road usable. Joe
#50
Rods are done and on their way to me...soon to be on their way to you.
#51
Any timeline on the valvetrain and cams?
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#52
The lead time on the valves was specified as 8 weeks when I ordered them. That has not changed to my knowledge.
I am ordering my bearings tonight... YEEEEHAW!!! Im getting excited!!!
Tom |
#54
Do you want to order my bearings at the same time too?
#55
What bearing will you be using?
Great job getting your rebuild off the ground, and mine too. Good job, keep up the good work. Michael
_______________ 92svxman & Freida the co-pilot. First 92 Claret(flat color,IMHO) Two 92 Teal(much nicer color) 5 Speed pending, from 93 Legacy Turbo 4.11 Tranny/rear diff. May go for 3.90 Claret 145K Underdrive Pulley from Newbies2005 New timing belt new radiator new water pump new timing belt cover New headlights and harness Replaced exhaust (with stock) Life on the road who could ask for more |
#56
well i ordered a set of Clevite bearings and NO dice... they only had .25mm over and .50mm over so I went with High Tech bearings... basically the same thing as Clevites and they are the only ones who carry std sizes. anyway I ordered them from partsamerica.com for a 1992 subaru legacy sport(turbo).
2 Main Bearing kits - Hi-Tech Engine Components: MS2062AL 2 conn rod bearing kits(not sold individually) - Hi-Tech Engine Components K1657AL4 Total of just about $200. Glad I got my ordered straightened out before it was too late... Just figured I would post for the rest of u guys tom |
#57
I just checked partsamerica.com and you are right, the standard size clevite bearings aren't coming up. I'll post the part # for them when I dig them out.
#58
i was on the phone with them and they said Clevite doesn't offer them... well they cannot get them at least... dunno. I am happy with the Hi-techs
Tom |
#59
Good Info.
I'd still like to do the ARP bolts and copper head gasket. Still considering closing or semi closing the deck as well. That will probably do it though.
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#60
The part #'s for the standard size clevite 77 bearings are:
main bearings: MS-2062 AL Rod bearings: CB-1657AL |
Thread Tools | |
Display Modes | Rate This Thread |
