Radiator needed ASAP!
I was wrapping up my next 4.44 swap on michael blues car today and as I was checking the fluids preparing to fire it up and test it all out I noticed the coolant was low. It took about 2 quarts of coolant and once I got it full I found the dreaded radiator tank crack across the top of the radiator. I think it happened when he took me for a test drive when picking up the car as I noticed a small amount of coolant on my trailer but none on the shop floor. Can anybody help out with a radiator for a good price quickly?
Thanks for posting this.
Any help greatly appreciated guys. At this point, my budget is blown and if anything else is found wrong with the car while he's got it I'm going to be forced to re-evaluate my situation. Any help greatly appreciated. Thanks!
'92 Pearl White LS-L Touring SOLD 4.44 Swap, trans cooler, trans filter, trans temp gauge Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines Raxles front axles |
Sorry my spare is cracked at the top....
sure hope you find one soon.
MOMZSVX 92 LS-L parts 94-LSi My baby 95-(AWD) polo green T-Boned |
http://svx-motorsport-accessories.st...eradiator.html
And http://cgi.ebay.com/ebaymotors/ws/eB...m=330103248163 Are probably pretty good bets... cheapest OEM radiators I've seen... |
Try Subaru Parts Central.....
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
Do the Epoxy putty repair on it. Most everyone who has done it has had it last for awhile, at least long enough to round up some $$ for a new one.
Make sure it's very clean, and scuff it up with some sandpaper and it should get you by..
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com |
It's SVX Parts Central, Get it right. I may just do the epoxy for now. Any recommendations on a brand or type for a long hold?
Patch
Fiberglass will help it last. Work the epoxy into the mesh. Good Luck.
spend $40 on a plastic welder.... lay a couple beads of the white material over it properly and you are all set
Tom |
