Old 01-08-2007, 11:55 PM
bakerman1 bakerman1 is offline
*..Programming keyfob?..*
I just got a replacement keyfob from keyless ride and followed the programming instructions. I couldn't get it to go into programming mode? security light off, ignition on, off, and then push security button fast till horn starts to beeps and lights flash. no beeps, and no flash? what am I doing wrong? please help...thanks
Ken
Old 01-09-2007, 12:19 AM
92svx95 92svx95 is offline
try this
• Start the car.
• Turn the security system OFF if it is on (security switch light OFF).
• Turn the key off.
• Turn the key on, but don’t start the car.
• Turn the key off.
• Rapidly push the security switch on and off until the horn begins honking. In program mode, the parking lights will flash, and you will hear a clicking noise from the security system behind the glove box. (Possibly, newer models won’t have sound this because the security system was relocated to the trunk.)
To program the remotes to the system:
• To program one remote, press the remote button 4 times.
• To program 2 remotes press the remote button 2 times on each remote.
• To program 3 remotes, press the remote button 1 time on 2 of the remotes, and 2 times on the 3rd.
• To program 4 remotes, press the remote button 1 time on each remote.
Note: The parking lights will turn on when a button is pushed and turn off when a button is released.
To exit programming mode:
• Turn the key on.
• Turn the key off.
The parking lights will stop flashing and the security system is ready for use
Old 01-09-2007, 11:16 AM
Tried it and still no go, but also I tried to set the alarm without the remote and nothing happened when I opened the car door after the alarm had been set for a couple of minutes? My horn works, and the security light on the dash works...what do I try?
Ken
Old 01-09-2007, 09:48 PM
When you set it, does the light flash or is it solid red? It should flash. If it doesn't work, you may need a new security module.
Old 01-10-2007, 10:31 PM
Where would I find this security module on the car? And is it just an unplug and replace thing? Thanks for the info.
Ken
Proud owner of a 92 LS-L Claret with 120k
Old 01-11-2007, 06:16 AM
Ken
It's located above the glove box on your 92....
