Koni question
Just installed konis all around. There is a knocking coming from both fronts like bad top mounts.
Does any one know if this is normal? If not any idea what may cause it? I really don't want to take them out to change the top mounts unless I have too. |
and the knocking wasn't there before you did the Koni install? Are the inserts tight in the strut housings? are the top mount bolts tight? are the sway bar bushings in good shape and the hangers tight? I'd suggest getting the car up on a lift and start pulling at the tires, etc. to see if you've got anything loose in the front end.
-Bill
Sounds like you didn't get 'em seated properly into the mounts. Happens to me about 1/2 the time when I do the rears on our racer.
Poly bushings will make more noise as well but that's usually just creaking. Personally, I wouldn't touch them on a street car. They're embarrassing for not much advantage over comparably new rubber. Reason most think they do so much is b/c they replace 10-15 year old rubber with a brand new product. If they simply replaced it with new rubber they'd notice 98% of the improvement without any disadvantages. |
earthworm, i've heard pros and cons of both bushings new oem ones and poly urethane ones, and from what i've gathered is the oem ones are good for your regular daily driver and the poly ones are used for your more vigorous race interested drivers (nothing new there), BUT the big thing i learned is that the poly urethane bushings are more prone to stiffening and cracking and need to be regularly oiled, much more upkeep. I am all about upgrading old oem parts, but this specific upgrade seemed like a bit too much of a hassle.
If i've been misinformed, please correct me! |
Yes earthworm, I know that but stiffer has its advantages and very distinct disadvantages. Stiffer doesn't always make her purrrrrr more ya know esp if she's on the street. Most people don't understand this and then wonder why their car groans and creaks over every pothole. Sure in a system the improvement will be noticed but improving 1 aspect only makes the weaker points weaker. |
The struts are definitely seated properly. Took them out and took off the mount and spring mount to make sure the washer was there them reassembled and reinstalled. There are no rubbers on the springs.
My mechanic has used "electronic" ears to isolate the source of the knocking and has determined that it is coming from inside each front strut mechanism in the lower portion. As I didn't build these myself I don't know the intricacies. It seems that either a. the konis constantly knock or b. they have been assembled incorrectly. Is there anything you can mess up in assembly which would cause a constant knocking? The best way I could describe it would be like a heavy piece of ice bouncing on each fender. A dull heavy knock. I sure hope this can be fixed. It sounds like I'm driving a beat off pickup truck. |
Wait a second, you have no rubber doughnuts between the strut and spring and spring and strut mount, its just metal on metal? Where are your cushions?
if you havent thought about it, check to make sure the battery is in there solid and not sliding around. i heard "knocking" as well...turns out the battery brace i am using sucks hardcore and has a hard time holding in the Optima Red Top in there
98 Impreza Wago-O-Doom & Datsun Roadsters |
Thread Tools | |
Display Modes | |
