Old 11-24-2006, 10:17 AM
nexus_7 nexus_7 is offline
My rear radius arm bushing are broken.?!
What kind of part # is that. I cant find squat! Also boes by control arm. but I just want the bushing and all the places only seem to sell the whole arm.
Ok, so I can only order the ARM. That sucks, What a waist of $.
2 20252PA000 Pillow Ball Bush
1 20251PA010 Bushing Lateral Link
1 20251AA021 Bushing Lateral Link
One of these?
I could use some quick help here.
Have the car at the mechanic and they told me those are broken to pieces. Always fun with the SVX.
Thanks
Greg
Old 11-24-2006, 02:35 PM
SVX_MY_BABY's Avatar
If by radius arm you mean the trailing arm then you are stuck with replacing the whole arm to get the bushing as far as I know. I just had mine replaced yesterday.
The bushings for the lateral link and pillow bushings are for the two bars which run from your wheel assembly perpendicular to the side of the car. The trailing arm is the one from the wheel assembly parallel to the side of your car.
Old 11-24-2006, 03:39 PM
Just checked subaruparts.com
2 20251PA010 Bushing Lateral Link $10.58ea
2 20271PA010 Bushing T/l R $32.10 $24.46ea
[OUT OF STOCK]
Old 12-04-2006, 10:45 AM
I've replaced just the bushing before so I know it can be done.
Old 12-04-2006, 08:32 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
David,
What did you replace them with? Stock bushings or aftermarket urethane pieces?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-05-2006, 05:10 PM
Originally Posted by SVXRide
David,
Sorry...only stock. I have to change another one soon...right rear front outer lateral link bushing.
Old 12-05-2006, 07:46 PM
SVXRide's Avatar
Sorry...only stock. I have to change another one soon...right rear front outer trailing arm bushing.
David,
Are you using the same tool you used on the rear diff bushings?
-Bill
Old 12-06-2006, 07:40 AM
Are the part numbers I listed above the ones you actually get?
Old 12-06-2006, 11:39 AM
David,
-Bill
That is correct, sir.
Old 12-06-2006, 11:47 AM
Pictures probably help:
You mentioned:
- 20251PA010 Bushing Lateral Link $10.58ea (Item #2)
- 20271PA010 Bushing T/l R $24.46ea (Item #7)
I've replaced Item #22 (same as Item #3) on mine.
Old 12-06-2006, 04:38 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
You mentioned:
We need to find a way to replace the bushing in #6. That was one of the units I sent you, hopefully you can come up with a solution as you seem to have access to more information that I do.
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 12-06-2006, 04:43 PM
yea, too bad you all couldn't have told me all this like a Week or 2 ago!
Greg
Old 12-06-2006, 04:49 PM
That's # 2 & #7 right?
Or is that a #21 shown and not a bushing at all?
