Old 10-29-2006, 07:55 PM
Bxsvx Bxsvx is offline
How fast is fast?
Send a message via AIM to Bxsvx
thousands of dings on door
any body experts know how to take out all those thousands of dings on the door? I literally have like almost one hundred but yo0u can only see it in the sunlight by looking down the side of the body. I was thinking to change the skin on the door, but i dont see that part on subaruparts website
Old 10-29-2006, 08:31 PM
It would be much cheaper to have your bodyman sand the door, fill the dings with filler, sand and repaint.
You could get another door from a parts car, but it may have dings in it as well. A new door, at $500 plus shipping, would still need installation and paint.
Old 10-29-2006, 08:43 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Look up: paintless dent removers. They take out dings from behind the panel, no filling, sanding or painting. It's fast and really amazing. Expect to pay around $100 to remove 3 or 4 dings on one panel.
Old 10-29-2006, 08:50 PM
It's Just Eric's Avatar
Missing in action
+1 on svxcess. Dont know about the ding remover dealies...all I can think of is another redundant Billy Mays yelling at me commercial....
HEY, BILLY MAYS HERE WITH THIS AWESOME NEW CAR DNT REMOVER!!iNTRODUCING THE NEWLY REDESIGNED DING KING!!.....
Best way would probly be to take the door off, remove the lower body cladding, tap off mabey a half inch around the entire door, and use good ole paint stripper on the mess. Clean up the surface and edges with some 220grit on a da (Random orbital sander) and roguh up the dinged areas with some 60. Smooth the whole thing over with some body filler. youll need to apply more than one layer, of course.you should sand the body filler first with 60, then 120, then 220 to finish it off. Run your hand down the panel repeatedly and feel for ANY dents, dings, or high spots. If you can feel it, you'll see it when its painted.Youll want to focus some attention at this point to the lower molding thing you pulled off. Run the da over that with some 400 grit and feather out any chips or scratches. To do this without making a butthole of it, hold the da nice and flat, and dont hold it in one place.Look to sand the area untill the edge of the chip or scratch is no longer visible. Once again, run your hand along it repeatedly and feel for any low spots (Creaed by you digging with the da) or edges. next bomb on some primer. Start off with two or three coats on the bodywork itself, then give the entire panel a a coat or two for good measure.On the lower panel thingy youl want to put a layer on wherever you broke through the paint down to plastic. Dust on some spray paint to use as a guide coat for wet sanding. Wet sand the door with a block and some 400 grit. Make sure you have every bit of the primer's orange peel removed. The panel should have NO guide coat on it whatsoever, and if you did it right, it should be the smoothest thing you've felt on an automobile
Now you gotta scuff your fender and rear quarter for a blend. The best and most drivewayable solution is to wet sand the panels with 1500 grit sandpaper and a block (Be it hard or soft) untill the clear coat's peel patern is gone (By the way...if you want any paint job to look good...do this to it and then buff it...at your own disgression of course)
now all you have to do is hang the door and drive it to your local body shop. all they have to do is tape it and shoot it, clear coat the door, fender, and rear quarter, and viola! your door doesnt suck anymore (Unless your bodywork wasnt good...then it probly looks worse right now)
....Or pay someone to do it for you, probly the safer bet if you know a good place.
R.I.P Cool Signature.
Old 10-29-2006, 10:17 PM
kwren's Avatar
kwren kwren is offline
Exclamation get a handicap sticker!
Get it repaired and get a handicap sticker so you can always park away from other cars! Try to park in the wide van access spots!That is what works best! Well actually it works a little better if you are really handicaped.
Old 10-30-2006, 03:54 AM
dannmarr's Avatar
I work for my SVX
Paintless dent removers is not a product, they are proffessional body men.
Old 10-30-2006, 04:38 AM
Try them first.
One of those body repair outfits was at the JAE show in the UK in July. A couple of our guys got some dings repaired, and one or two of the dings were SERIOUS! I really could not believe how good the results were without a respray.
If those dent removal guys are good at their jobs, then it is well worth paying the asking price, before you go for a respray that runs the risk of a bad panel match.
Old 10-30-2006, 03:16 PM
wannarace928's Avatar
wannarace928 wannarace928 is offline
Send a message via AIM to wannarace928 Send a message via Yahoo to wannarace928
Classic SVX
Go to an autoparts store and buy one of the ding remover tools. Some of them work pretty well. I had a baseball size dent in my car and bought one of the tools and it looked good as new. They have all different kinds and sizes depending on how bad the dings are. Only other suggestion is to take it to a body shop.
Old 11-02-2006, 04:51 PM
How fast is fast?
some are like dings and some are like uneven ripples, its read hard to explain, all i know is that its not smooth in the sunlight and its wavy. Its the original paint, it hasnt been painted over. I wish I could show a pic!!!!
