Old 10-27-2006, 04:01 PM
Jade Dragon's Avatar
Jade Dragon Jade Dragon is offline
Don't screw with the Dragon
Send a message via AIM to Jade Dragon Send a message via Yahoo to Jade Dragon
fan issues
so, i have an intersting problem. For about a month and a half now. my fans will not come on. i know the problem isnt related to the AC, because they have worked before with out the AC system running (no coolant, so i dont use it at all) But now, they dont turn on when they should. I start to run hot at idle, but once i start to drive it goes down to normal. I have looked at the fuses, and the relays and i still have no idea whats wrong. HELP!!
->Austin<-
1992 Pearlie (Pearl): motorsport exhaust kit (Wife's)
1994 Red FWD (Roxi): Custom X exhaust
Old 10-27-2006, 05:08 PM
Shadow_Myst Shadow_Myst is offline
Have you tried applying direct voltage to the fan moter? If so what was the result?
Best of luck
Old 10-27-2006, 05:56 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Temperature sensor?
Old 10-29-2006, 03:44 PM
edmsvx's Avatar
edmsvx edmsvx is offline
AC fuse?
Check the AC fuse in you engine compartment fuse box. It this 10 amp fuse is bad the fans will not come on.
I discover this as I had the AC compressor bearing sieze and it shorted out the AC clutch (blowing the fuse). Disconnected the connector on top of the AC Compressor and replace the fuse and fans came back to life.
1992 (JDM) CXD Ebony Pearl 90K km written off hail damage
1996 (CDN) Lsi, Polo Green, 296,000 km
2009 Legacy Spec B
Old 10-29-2006, 04:20 PM
dwd1985 dwd1985 is offline
I had the same problem when I first bought my SVX. First, unplug the engine temperature sensor, and start the car. If the fans stay on the entire time, then the culprit is either the sensor, or the fan relays in the fuse box under the hood. The best way to figure this out is to re-connect the engine temperature sensor, pull all of the fan relays, and plug them back in in different spots. They cant all be bad, and you should eventually get the good ones in the right order to start either the right or left fan.
New relays run about $60
Old 10-30-2006, 04:27 PM
The AC fuse is fine. no problems what so ever. The relays are probably the culpret(spelling) so ill have to so some working at it to get them to come off with out breaking the tabs.
->Austin<-
